Question about Maytag Performa PAV2200
Maytag Performa MDE3500 AYW
My electric dryer began running excessively hot last night and even began to smell like smoke. After allowing it to cool overnight I plugged it in this morning and turned the timer on. The drum immediately began to get very hot as well as the outside top of the dryer. Any advise on areas to check?
  • 19 Answers
SOURCE: Maytag performa
Sounds like your motor brushes are very worn.(Its a bit like grinding metal when a cars brake pads are worn.)Should only cost 10 or so pounds for new ones,access to the motor will be required.Unplug washer b4 changing.
Posted on Aug 25, 2007
SOURCE: maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Posted on May 03, 2008
TheMobilian
  • 8220 Answers
SOURCE: My maytag performa model number Pav 3200 IS SMOKING
Pump locked up Tip the washer over and take the belt off. try to turn the pump both direction. look for seperation in pump seal. Very easy to replace. Tools needed 3/8th nut driver. water pump pliers. pump is 30 bucks
Posted on Dec 17, 2008
  • 2920 Answers
SOURCE: maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Posted on Jan 12, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: squeal then smoke
Bad motor or you are your drum is rubbing on the maching. What does the soke smell like? Like electrical or plastic. I also recommened that you do not use this until either we can get it diagnosed for you or you call a service tech
Posted on May 16, 2009
My Maytag Performa PYE2300AYW keeps running and won't get to hot on low but on Regular it gets too hot
your cycling sensor thermostat is getting defective it will have 1 side a red wire coming off the heat selector switch and the opposite side will be a yellow wire from the safety thermostat connection
Nov 15, 2009 | Maytag PYE2300AY Electric Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Odor from Maytag dryer
Have you cleaned your vent lately? It might be excessively outgassing an ammonia smell because some plastic part that is getting too hot. If the vent is making it run hot or not exhausting it might stink up the room. Otherwise, it might just be stinky plastic. I don't know anything about your specific model, but I had a bread maker that was the source of a garlic & ****-like ammonia smell on the top cover after the plastic turned yellow from heat & age. Not a good feature for something that makes food and lives in the kitchen.
May 11, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Performa washer smoking and smell of burnt plastic
It could be the pump or the motor overheating.
Remove rear panel, and run washer through a rinse and spin cycle.
After it has finished, unplug the washer, and feel the pump and the motor, they should be relatively cool to the touch.
If either the motor or pump feel hot, then that is probably the cause of the problem.
Also check for a worn or slipping drive belt.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Maytag Washing Machines
Maytag neptune smoking
Jan 12, 2009 | Maytag Neptune Washer
Maytag Dryer
the high limit switch may be malfunctioning. i would have it looked at by a professional. this could be a fire hazard.
Jul 10, 2008 | Dryers
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
