Question about Samsung SC-D23 Mini DV Digital Camcorder
Samsung digital camcorder model no. sb-l110
Hi i recently got my camcorder out the cupboard as our daughter is in a show and when i turned it on to have a go it records sound but no picture even when not recording still no picture
  • kchelle Nov 03, 2007
    It is fully charged everything but the picture works fine. The picture is completely black. It has picture if you play a tape. Nothing but black in the view screen whether just trying to view or record. I have taken it to a repair place they said I have to contact Samsung because they can not fix it. ? Help is appreciated.
  • Anonymous Nov 13, 2007
    Got the scd23 camera, used about 15 hours and black screen in camera mode. Has little white lines going through it. Same with my mother-in-law who bought the same camera at the same time.
Lcd monitor color set 18-36 or more
Posted on Dec 16, 2007
SOURCE:
My camera,s model is nikon coolpix l110. But unfortunately showing message your memory card is write protected , that's why i can not take any picture.So please fix this problem.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2011 | Nikon Coolpix L110 Digital Camera
WHERES THE MODEL NUMBER ON A SAMSUNG SL105
I can't find a picture but the numbers are usually on the underside
Dec 15, 2010 | Samsung USB Data Charger Cable Type12...
My lcd won't display a picture. it is white with colored lines going across it. If i flip the screen it used to show the picture, but now will just show a blank screen. I'm thinking there is something...
the connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
Jun 30, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
SAMSUNG DIGITAL CAMCORDER MODEL VP-D102D
Go to this link it is the manual on page 93 or 97 it will tell you fow to turn off protection.
http://downloadcenter.samsung.com/content/UM/200405/20040531104833937_B-SCD103-SEA.pdf
Good Luck
Jan 17, 2009 | Samsung SC-D105 Mini DV Digital Camcorder
Samsung VP-D102D Camcorder
Remove the DV tape from the camcorder and check the position of the red tab on top of the tape. Reverse the position and see if it protection goes away.
Daughter accidentally cut software installation disk opening it.
My daughter cut the software as well. 5.1 MP Digital Camera. Can I buy the installation disk only somewhere.
Dec 27, 2008 | Sakar Digital Camcorder
I recently picked up a Canon UC-X1 Hi 8 camcorder my father left me when he died. I have been trying to view tapes in it but it has bad distortion... and interference so makes it very difficult to view. Is...
Hi bumble
Yes, it may be dirty heads, or a loose maladjusted tape guide, but also(more likely) could be failing surface mount capacitors. Canon camcorders of this vintage were plagued with problems from these failing. Best bet is to have an experienced video repair guy to have a look at it for you. If you dont care what outcome you get, then I could talk you through giving it a tape path service:) Just give me a shout in here.. :)
regards
robotek
May 07, 2008 | Cameras
Samsung problems
DOES IT RECORD PROPERLY ?
IT MIGHT BE A BAD BOARD INSIDE . YOU HAVE TO DESCRIBE THIS PROBLEM BETTER
Dec 28, 2006 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D23 Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
