Question about Oregon Scientific BAR339PA Atomic Color Changing Projection Alarm Clock
Projection is reading upside down when laying down on the model BAR339PA
My htc wildfire s pictures come out upside down
You need to calibrate your screen. Go onto menu then settings then display. At the bottom it says g sensor calibrate. It tells u the instructions, u have to lay it flat on a surface while it calibrates. It works. I did this, I wanted to calibrate it properly before it started taking pictures upside down and I had read the instructions wrong and stood it up on the surface. I'm very crazy. This will work, if it doesn't then ur phone is faulty
Feb 04, 2012 | HTC Wildfire Cell Phone
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Image is upside down. how to fix?
Projectors have the ability to flip the image for when they are ceiling mounted, or laying on a desk. You have to go into menu and change the option based on where you have the projector located. You can find the option in the Menu, under Setup and Basic under the Projection sub-menu. Will be either Front Table, Front Ceiling, Rear Table or Rear Ceiling.
Jan 27, 2011 | Vivitek D940VX Projector
My ps2 disc will spin for about 15 seconds then stop
the motor bearing is bad,is your ps2 standing up or on side, try different posistions. worse case sinaerio get new motor.
Mar 20, 2009 | Sony PlayStation 2 Slimline Console
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Toshiba tp5581a 55 in. rear projection tv.....problem
the yokes need adjusting (upside down writting) and the CRTs need alignment
Sep 11, 2008 | Toshiba 50H81 50" Rear Projection...
Upside down screen
ctrl+alt+up arrow should do the trick for you
May 15, 2008 | Toshiba Satellite A105 Notebook
Menu
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Thanks for using Fixya !
Apr 30, 2008 | NEC VT676 Multimedia Projector
Oregon Scientific BAR339PA Atomic Color Changing Projection Alarm Clock Logo
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
