Question about HP Compaq Presario M2010US Notebook
User environment error message and HDD fail of Test #2-07
I receive a weird error message at startup, it only stays up for about 25 seconds, so here is the gist of it: "User environment- Windows cannot load the locally stored profile because of insufficient security rights or corrupt local profile. A 1/0 operations initiated by registry failed." It then automatically takes me to a profile which is not mine, and it acts like it is a Guest Profile, i.e. prompts me to tour Windows XP, internet explorer does all of the prompts of a freshly downloaded program. Also, the PC is freezing up constantly for about 30 sec. Have done a disk defrag (but it defragged with errors) and an HDD self test (where I received the Test #2-07 failed message). The Hard drive is only about 4 months old (HP replaced it while it was still under warranty). The very last thing I did to my computer before I received the error messages was download LimeWire PRO, I do not know if this is related or not. I have uninstalled LimeWire PRO just in case. I set up a Guest account right know (not the one that I am automatically taken to on a normal startup), and the PC has stopped freezing. I would really rather not buy a new HD, since my warranty expired. Should I re-format, go to Geek Squad?? Help!
    President:
  • 2,961 Answers
I would suggest that you restore your pc back to a previous date and see if the 30 second freeze ups go away. This has happened on a few of pc's i have had, but the reason i put it down to was a corrupt windows update or one of window malicious viral scans. Go to start>programmes>accesories>system tools and select system restore. When opened up choose a date previous to when this started happening or choose a date before the last updates or system check, only dark lettered dates can be restored the greyed out dates cannot.
Posted on Jul 11, 2007
How fix computer sayin user profile cannot be loaded
Hi Anon
Please follow the instructions in the link below to fix your user profile problem.
Aug 13, 2014 | Microsoft Windows 7 Ultimate for PC
Windows 8 error code 0xc000000e
Hi I have this error code 0xc000000e windows 8, You get three options,
1. Enter to retry
2. Press F8 for start up settings
3. press F9 for to use a different operation system.
First two options do nothing, F9 will restart computer, and the I can boot from the boot disk. I have tried to rebuild the startup files, from the disk nothing is working. I can't get into the Safe mode. Guess only option is save all files to a back up HDD, I even tried to restore to a past date.
Nov 17, 2012 | Computers & Internet
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
Dell Vostro 3500 running Windows 7. Trying to log into the admin (only) account and get the message: The User Profile Service service failed the logon. User profile cannot be loaded. No Recovery Media was...
Please check following link from Mocrosoft knowledge base:
Error message: "The User Profile Service failed the logon. User profile cannot be loaded", when logging on to Windows 7 or Windows Vista
http://support.microsoft.com/kb/947215
PS: If it helps then please click on thumbs up.If you need more help then please let me know.
Sep 20, 2011 | Computers & Internet
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Fatal Error: Loading module SGEDRV.dll failed (Error #126).
Right Click om "My Computer" and select Properties | Advance Tab | Environment Variables.
Select Path Variable in the lower part of the box by clicking on it and add C:\Program Files\Utimaco\Safeguard Easy
Note: To insert ; (semi colon symbol) after the previous path
Thank you
Dion S
May 06, 2009 | Microsoft Windows XP Professional With...
HP Compaq Presario M2010US Notebook Logo
895 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
