CAN NOT TUNE IN SHARP GA608WJSA 14 tv - Televison & Video
What is the number of str ic,regulator power supply a 14 inches sharp tv. model primo sharp tv 14 inches
Try the site linked here. It has schematics of power supply section to many popular brand TVs. http://electronicshelponline.blogspot.com/ Hopes it will help you to check out the number of the STR.
Dec 18, 2013 | Televison & Video
Sharp 14" crt tv model598WJ
What is the problem with your Sharp TV? Provide more details please.
Sep 26, 2012 | Televison & Video
How to tune thomson tv 14MG135
first is to get it from AV mode which suggests it is on one of the rear audio/video inputs.
If no source or Tv video button on remote look in the menu--once off the AV input it should be able to tune.
Direct hookup with cable or what?
May 02, 2012 | Thomson 14MG135 14" TV
I cant tune in my tv its a sharp dv5103h abd i have lost the manual
Dear customer,
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
   Setting Up Your Sharp TV
Turn on your TV.
  1. On your Tune In remote, press TV and release.
  2. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  3. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  4. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
U can also refer to the following link for ordering manuals  http://www.aerialsandtv.com/tvservicemanualsmainpage.html
Plz rate this solution..
Apr 09, 2009 | Sharp Televison & Video
How do you tune in a Sharp tv
You need the remote to tune direct. You can find a replacement HERE.
Apr 08, 2009 | Sharp Televison & Video
How do I tune my Sharp TV G0833PE to Foxtel
what is foxtel? is it a cable company? or satelite company?
Jan 07, 2009 | Televison & Video
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP TV CHANNEL LOCK
Probably the best way is to contact SHARP directly. The owner's manual can be downloaded from SHARP's homepage for free.
Sep 16, 2007 | Sharp 25L-S100 25" TV
Sharp Tv, can't tune in channels
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Aug 16, 2007 | Sharp 14U-FM1 14" TV
HOW TO TUNE GRUNDIG 14" TV
for tune your grundig you must use remote control
May 09, 2007 | Grundig GF70-600 TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
