Question about Ricoh Aficio 150 Copier
RICOH Aficio 150 Paper Jam Reset
Have a RICOH Aficio 150. Showed a paper jam in Zone "B." Cleared it out, shut the compartment door,and can't get the "paper Jam" error to clear. Does anyone know the factory reset on this machine? I am 100% certain there is no more paper in the jammed area.
    New Friend:
Paper jam
Posted on Jun 13, 2012
  • Ricoh Expert
  • 1,326 Answers
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
SOURCE:
Had a paper jam and now can't get door to shut
If you're talking about the duplexer door not shutting after the paper jam, check if the transfer roller has fallen off into the printer which is preventing the door from closing.
Mar 12, 2014 | Ricoh Aficio Mp-C300 Color Copier
I have a ricoh aficio 2022 and the problem is that sow error j001 jam at the c section but there is no paper stuck on the printer
first is clean the sensors especially the exit sensor, check also the door switches maybe they are not functioning well so the jam will not be reset
Jan 22, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
Paper jam was cleared from the bypass tray.. still says paper is jammed.. there is nothing in it
u have to check the paper path sensor located in the door unit .and also check the fuser for paper jam
Sep 15, 2011 | Ricoh Aficio MP1600SPF Copier
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
Our Canon ImageClass D860 copier had a paper jam. We cleared the jam and did everything we were supposed to do and it still says Paper jam on the screen. We've turned it off, unplugged it and still it says...
There mite be some paper dust on the sensor where the copier indicate the paper jam is. some can air mite solve the problem. Be careful to direct can air towards the outside of the copier don't want to blow the paper dust to a different sensor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 12, 2009 | Ricoh Aficio 2015 Copier
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Ricoh aficio 150 paper jam
There are pressure release levers on the fuser --- if they are not in the correct position they will not apply the proper pressure and you will get jamming in that area. The levers are either a light green, light blue or plain black. They should be on the left and right side ( looking in at the fuser. Turn/ flip them and check.
Dec 02, 2008 | Office Equipment & Supplies
2,161 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
