Question about Dynex DX-32L151A11 32-inch Flat Panel LCD HDTV - 720p - 300 cd/m2 - 16
Backlight too bright on technika screen - Dynex DX-32L151A11 32-inch Flat Panel LCD HDTV - 720p - 300 cd/m2 - 16
Backlight spoilt for dsc t90
When the display is to dark or to light, the manual says:
Adjust the brightness of the backlight (page 18).
On page 18 it says:
This sets the brightness of the LCD screen. When viewing images in bright outside light if [Brightness] is set to [Normal], reset to [Bright]. However, the battery power may decrease faster under such condition.
You also can press the button with the > logo, to change between view pictures and record.
Dec 08, 2013 | Sony CyberShot DSC-T90 Digital Camera
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | RIM BlackBerry Pearl 8100
The laptop has a black screen. Yo9u can see it a little in a very bright light
Assuming you have adjusted the brightness as far as it will go, then the backlight has burned out. Most laptops have a florescent backlight. You must either replace that or replace the screen. Another problem might be that the backlight inverter might be bac.
Jul 17, 2010 | Computers & Internet
Acer aspirw 5100 brightness
1.The Function key (Fn), and the F6 key are pressed to turn the Backlight off to conserve power.
2.The Fn key and the right side arrow key, are pressed to increase Brightness.
You have a TFT LCD monitor screen. (Thin Film Transistor)
The LCD screen cannot be seen clearly without a Backlight.
The Backlight is a CCFL. Cold Cathode Fluorescent
tube. Resembles a small fluorescent tube used in residential, and commercial lighting.
The Backlight can go bad after time, and weaken.
If so, it will have to be replaced.
Sounds easy, it isn't.
The TFT LCD monitor screen is made up of layers. It's enclosed in a thin metal frame. Resembles a picture frame.
The frame is removed, after removing the LCD screen from the laptop's top cover.
The LCD screen transparent outside layers, are separated partially from the rest of the LCD screen.
The Backlight is removed out of the side.
This gives you an example of removing, and replacing an average Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Recommended job for a pro.
Dec 28, 2009 | Acer Aspire 5100 Notebook
How do you make d screen glow?!?! is it possible (d same clock theyre decribing) d one with d stylus on the bak
You cannot make the Screen Glow however you can increase the Backlight brightness of the Screen
follow the Steps:-
Click Menu Key
Goto Options Icon
underthat select Screen/keyboard
then select Backlight Brightness option and increase the Brightness to 100.click on save...
Nov 09, 2009 | RIM BlackBerry Pearl 8100
My dell e1404 laptop is having a issue with the screen. When you turn on the computer the screen will come on for about 30 seconds and then go off. When it's on everything looks normal. once it goes out...
The inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. The inverter board converts low voltage DC power (few volts) supplied by the motherboard to high voltage AC power (few hundred volts) needed for the backlight lamp.
When the inverter board works properly, the backlight lamp gets power and the LCD screen lights up. As a result, the image on the screen is bright. If the screen is dimming down, means that the inverter is failing in it;s job to supply the needed voltage to the Backlight.
The Inverter is mounted underneath the display screen and is connected by a two wire plug.
Nov 07, 2009 | Dell Inspiron E1405 Notebook
Hanns-G HW191D LCD - Image there, just not bright! Monitor looks black
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Jul 11, 2009 | Hannspree HW191D LCD Monitor
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Dynex DX-32L151A11 32-inch Flat Panel LCD HDTV - 720p - 300 cd/m2 - 16 Logo
27 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
