Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
My Philip tv needs a tv card
I have a philip tv that got from a hotel here in N.Chas. SC and it had On Command attached to it and I need to get an original TV Card.
Chassis # 517Q091G
Model # PC 6225-C122
Serial No. 65679660
Please tell me how to order it, and if any idea where I can order it via the internet, at an original price..Thank you...Linda S.
  • neonladee200 Jan 24, 2009
    I need some type of tv card, my remote does not work the tv, I have to walk up to the tv to turn it on and off, I bought a universal remote and it still did not work.
  • DEKR
    DEKR May 11, 2010
    In am checking this out for you
    your not able to get the television on with cable plugged in
Call this number ask to speak to roger least {410-321-7400} about information about getting a flash drive with the tv original info stored into it, you can plug it up into the usb port in the back of your tv and it will program it to either work with the on command remote, or the original one, also check with the company service tech for the hotel u got it from, he may have the stuff u need to fix it, go thriught the enginering dept,
Posted on Mar 14, 2009
  • 1,102 Answers
I don't think you need a tv card your universal remote is probably not set up right
what is the remote type and on the remote tv button needs too be pushed
give me remote type and i'll try to resolve
Posted on Jan 24, 2009
  • DEKR
    DEKR Feb 01, 2009
    please rate me
Previosly I could use 319753 to unlock my philip hotel tv Tv Model21ht3154\01 but I change the security option to high and now I can't access the menu with the code again.pls I need help.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 19, 2014 | Televison & Video
You have to enter its service menu option to unlock the Hotel mode. Visit the site named 'Electro-help' for more details. Check this LINK and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs.
Aug 11, 2012 | Televison & Video
How can i unlick philips hotel tv 32hfl5662l/f7
How to switch your hotel Phillips 32HFL5662L/f7 to HDMI if you need to.
(I'm stuck in St Johns, Newfoundland, miles from the downtown....I must be bored)
1. You will need a serial DB9 M-F cable, your PC with a serial port and a terminal program like Hyper Terminal or Putty
2. Set your baud rate to 115200, n,8,1
3. Unplug the AC adaptor connecting the little smart box on the back of the TV. The TV may plug into this adaptor as well, so just plug the TV back into the wall. If you do not, the LCD TV will try to switch back to cable after you select HDMI.
4. Power on the LCD TV and you should see data on the PC screen in readable text.
5. You must send a carriage return after each command <cr> (the enter key on your PC)
6. Use only small letters (no caps)
i - info
u,d,l,r - Up, Down, Left, Right
p - PIP window toggle
To set to HDMI use the following sequence:
i <cr> (menu)
d <cr> (down)
d <cr> (down)
r <r> (right)
then use 'd' and 'r' to select the right input
Jun 13, 2012 | Philips Televison & Video
Is the 42" philip plasma
If you really want, you can use an old CRT TV as a monitor provided you get it connected.... so your plasma... YES. If your PC has a DVI port, you could use a DVI - HDMI cable to connect. If your PC does NOT have a DVI port, you could install a video card that does... better yet, get a video card that has a HDMI port. This way, you'll only need a HDMI cable to connect the PC to the TV for audio and video.
Aug 05, 2011 | Televison & Video
My hotel changed TV, I bought the Philip 30HF9975/12Z , but what we got is just the screen. Please help me what I need to get to get it working.
I'll assume that you work in a hotel. Do you guys feed a cable signal as is straight to each guest room or do you have you own system (i.e. separate receivers for each channel that are then combined into one trunk)? Do you guys offer a movie purchase option or allow guest to checkout through the TV? What system you guys use would determine what you'll need aside from the screen itself. These things should've been worked out before investing so much money on new TVs.
Jul 18, 2011 | Televison & Video
Need to know how to attach the stand, I have the parts that came with the TV but no instructions.
Very easy to attach the base.Just put in the base in long square whole matches up all the screws holes and put in like 4 Philip screws in and tighten it with a Philip screw driver that should have the base stable and hold the tv.
Jul 07, 2010 | Insignia LCDTV26 26 in. Television
Have super digital tv capture ... philip 7130 card
go 2 the phillips website and select download software for your model # on the card
Apr 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Need te code for programing a Sanyo TV, Philip SRU
Sanyo 0154, 0159 (manufactures codes)
hope this help you out if so please leave a thumbs up
Little Dish Fitter
Oct 07, 2009 | Televison & Video
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
Oct 17, 2007 | Philips 36PT41B TV
Televison & Video Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
