Question about Itw Devilbiss Itw Paslode Cnp 65Y Coil Nailer
Paslode im350 piston will not return
After firing the shaft that drives the nails will not slide back into position (ready for the next nail) without being pushed back up.  this is a pain in the neck. does anyone have any ideas?
  • patrick50892 Jan 30, 2009
    the problem was not the piston ring but the o-ring at the top of the chamber. whilst not broken a part of it was damaged, allowing exhaust gas, that should have pushed the piston back up, to escape from the top
  • 2,176 Answers
It sounds as if the piston o ring is worn. Does the piston drop if you just give it a slight bump with no nails in the magazine, if so that is the problem and would need replaced. Let me know otherwise and I will dig deeper
Posted on Jan 27, 2009
Paslode F16 finish nailer will not return to start position after firing. Need to pull it back.
You may have to disassemble it BUT it may be that the mechanism and sliding parts are dry and stuck with glue from nails etc so may also work to apply a rust solvent to the sliding parts and let it sit and work the nailer a bit etc.
Sep 21, 2014 | Paslode 1-1/4 In. Straight Finish 18 Gauge...
Paslode im350 fires every time,but nails dont come out
Unless you have the wrong nails or a problem with the feeder and/or feeder spring it is probably dirty and the driver is hanging up on the cylinder. These tools need to be cleaned and lubed after using them for some time. If you look on Paslode's website there is a manual that explains how to do it. There are also videos on YouTube that show this. It is somewhat complicated and the tool has to be disassembled quite a bit. If you don't feel comfortable doing this work then you may want to want a servicing dealer that repairs these tools. There is a rubber o-ring on the head and a filter on the top that should be replaced too. Here is a link to the cleaning guide.
Paslode IMCT cleaning guide
Aug 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Not firing right
the nail return spring for the piston is stuck or broken,dis mantle the gun and clean and check the spring to see if its broken
Apr 06, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 will only now wrk properly when on a flat surface i cannot fire in at an angle without it mis-fireing
Make sure the nails are inserted so that the follower maintains pressure on the strip of nails. Also, your pressure on the whole gun at an angle is probably not as great as on the flat---could lead to misfiring
Mar 02, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode impulse cordless nail gun,doesn't pull the piston back far enough to catch the next nail, so when I fire it no nail is picked up by the firing pin. batteries are good(new), cylinder is new, any...
This is an easy fix luckily usually it means that the chamber is dirty and all you have to do is open the top front of the gun so that you can see the piston then take a q-tip and clean the area really well sometimes it requires a degreaser and then when you think that you have it clean make sure to lubricate the chamber really well with the paslode lubricant that came with the gun or they sell it right next to where you get the nails. Then the gun should work fine with no problem if this does not work then this means that the piston might be bent and that could turn into a big problem but is still fixable just harder.
Hope that this works for you
Nov 25, 2009 | Tools & Hardware - Others
When I fire my im250 the firing pin often does not retract fully, so not letting the next nail to progress. I regularly clean and lub the gun and it fires all the time so the problem is not at that end of...
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Jul 30, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Itw Devilbiss Itw Paslode Cnp 65Y Coil Nailer Logo
1,305 people viewed this question
Top Itw Devilbiss Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Itw Devilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
