Question about Home Security
I have a Craftsman 1/2 hp 139.53663SRT2 garage door opener that has 2 remotes (visor) but won't work until the opener is fully reset (after ~4 1/2 minutes). It's worked fine for over 14 years. I recently replaced that batteries (tested fine with a DVM) but now neither remote works while the lights are on. I've reprogrammed numerous times (successfully) but still have the problem. Logic board? Thanks.
SOURCE: Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Posted on Aug 08, 2008
  • 244 Answers
SOURCE: Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Posted on Jan 15, 2009
moeshere
  • 33 Answers
SOURCE: craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: cant get 2 remotes for garage door openers working at same time
You have a remote that has reverted to an earlier technology. The only way out of this is to purchase the same exact model number called for by your opener and go through the programming. You will find the new one will work with one of the old ones. Remove the battery from the one that isn't and drop it in the garbage.
Posted on May 29, 2009
  • 4 Answers
SOURCE: Craftsman 1/2 HP Garage Door opener problem
The remote and the keypad work through a signal sent to the receiver while the wall console, as you said it's wired directly to the opener, so it's likely that the receiver is shot. I'd try reprogramming the remote to just rule out the chance that all code wasn't erased first. (Press the learn button on the back of the operator head, stand back 5 feet and within 30 seconds slowly press the remote button a few times to see if it operates the opener). If this doesn't work, you can install an external LiftMaster universal receiver with the correct frequency and you should be good.
If there's a purple antenna hanging off the head, this is a 315 freq, use a 356LM, if black it's a 390 freq, use a 635LM receiver.
Then you'll have to reprogram your remote and keypad to the receiver.
Since there's also the issue with the light, there's also a possibility the circuit board got fried. Did you have any storms lately?
Posted on Aug 07, 2009
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
Garage door programming doesn't work
try resetting the homelink system by holding down the first and last buttons at the same time until the light flashes rapidly on your visor. this could take up to a min. then at the same time press whichever button you want to program on the visor and the garage door remote button at the same time until the light on the visor flashes rapidly.that could take up to a min. after that is complete you need to go and push the learn code button on the back of the openers unit, then go and push and hold the button on the visor you just programmed until you hear a click or you see the light flash on your opener unit. after that try using your homelink. note there is about a 3 second delay when using homelink. you need to push and hold the button until you see the door operate.
Sep 10, 2012 | 2007 Mercury Grand Marquis LS
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not open or close door when temperature is cold.
if this is an outside remote the best you could do is maybe put someting to insulate the remote if it is in your car don't leave it on the visor put it in the glove box or maybe the center console it is obvious that expansion/contraction physics are playing a part
Apr 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
107 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
