Question about Dryers
Manual for moretti mfs1600R fan
Moretti mfs 1600r
2 Suggested Answers
  • 3698 Answers
SOURCE: moretti heater manual
www.moretti.com.ar/downloads.php?id=132
homeappliance.manualsonline.com > Household Appliance
Posted on Jul 03, 2014
Download 5.2 kw moretti cooling only air conditioner manua
Tough One
Couldn't find it here
http://homeappliance.manualsonline.com/manuals/device/air_conditioner.html?page=5
I think I saw the Manual HERE
http://homeappliance.manualsonline.com/support/other/air-conditioner/air-conditioner-5415960
Mar 02, 2015 | Heating & Cooling
Hi I have a Moretti 1800BTU portable air con and its started beeps 10 times on and off throu the day and night
Liza I hope you still have your owner/operator manual it sounds like to me its set up on economy mode. Check your operators manual and check set up.
Dec 29, 2014 | Heating & Cooling
Hi, looking for help or copy of instruction manual
Always look on line for manuals. Go to Moritti site and search for your model #.
Sep 01, 2014 | Heating & Cooling
Moretti heater manual
Jul 03, 2014 | Heating & Cooling
Moretti elite mca200a convection heater
http://www.manualsdrive.com/results.php
I have a Moretti elite 50cm pedestal fan that has stopped working since I accidentally unplugged it from the wall. Is it totally broken?
i have same problem anyone solve the problem cause i couldn't find anythink on that site
Jan 01, 2012 | Dryers
My bright lights do not work on my 02 ford f150. Where would I begin to look for the problem?
When you say they do not work, is this with the MFS ( MultiFunction Switch ) pushed forward to bright, or with both the high ( MFS forward ) and FTP ( Flash To Pass, pulling back on the MFS lever ) ?
Did you check the fuse for the high beams ? ( Cab fuse panel, fuse # 16 ) with a meter or test light on both pins on the back of the fuse ? To have power on this fuse you need the main headlamp switch turned to the headlamp position, and the MFS pushed forward ( or holding the FTP function ).
If you have power on the fuse with the MFS forward, it would be a bulb issue ( burnt out ) , time to check the bulb connector for power when the high beams are on, this is the Light Green w/ Black stripe wire at the bulb connector.
Directions in your owners manual on getting to the bulb connector by removing the headlamp housing ( ie. changing the bulb ).
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Jan 10, 2011 | 2002 Ford F150 Regular Cab
Wipers only work on fast speed. The intermitten will not work. When you turn them off they stop at that position.
This is most likely a problem in the Wiper stalk control, although the wiper motor should complete the wipe cycle and Park the blades.
The wiper control is a part of the multifunction switch that it is mounted in. The switch is called an MFS and it is usually replaced as a unit. To replace the MFS switch you will need to remove the steering column cover and on some models, the Ignition switch. The Ignition switch may have a wide round flange on it which will prevent the plastic steering column cover from coming off when you want it to.
The problem can also be in the connectors which attach to the MFS, so I would recommend checking for a loose fitting connector and then trying the wipers again. Be careful not to break the tabs holding the connector to your part. Look for corrosion in the pin connections.
There are several female Torx bolts holding the MFS in position. They will have to be removed and replaced to change the MFS. It is not impossible that the wiper motor is also bad. You will know if the blades still refuse to Park. The intermittent feature and the speeds are part of the MFS switch and that part should work once the MFS is replaced.
If this does not sound like a job you want to perform, a Body shop or Independent mechanical shop can do the job; so can a Dealer. The MFS can run between $65-$95.
Nov 20, 2010 | 2000 Mercury Grand Marquis
Adaptor for DEH-1600R ?
No other way than use FM-transmitter. There is no RCA-in connectors in unit.
Here is one FM-transmitter.
Oct 10, 2008 | Pioneer DEH-1600 CD Player
Dryers Logo
Top Dryers Experts
