Question about Acer Aspire 3610 Notebook
BLANK SCREEN I have an Acer Aspire 3610 and when i try to turn it on the power button will light up green but i only get a blank screen. I can hear the fan or motor from time to time but i still cannot get the screen to come up. i have tried f8 but i am either not doing it right or something, Please help me i am ready to throw this thing out a window!
  • melissa aaglan Jul 11, 2007
    I tried to add a external monitor and that did not work. Any other ideas? I think it might be stuck in sleep
  • 3 Answers
Hi, I have encountered the same problem after upgrading my memory. I removed the new memory and so far so good.  By chance did you add memory and then the problem started ? Also my Acer has a DVD reader only, some models I believe could come with a DVD burner. Not sure if that's a possible clue. I'm going to check for a BIOS update. Hope this may shed some light on your problem.
Posted on Oct 18, 2007
I have a pair of Acer Aspire 3680 that does the same too, I just hold down the power button and cycle the power. I think it's a design flaw where it hangs because it cannot properly detect a device. My guess is the DVD drive because it hangs on boot whenever there is a disc in there.
Posted on Aug 28, 2007
Your LCD display could have gone bad. Try hooking up an external monitor to the laptop. If the external monitor works, then your LCD is bad. If that's the case it may be more cost effective to purchase a new laptop. Prior to doing so, I would check with Acer to find out how much they will charge you to replace the LCD. Good Luck!
Posted on Jul 11, 2007
SOURCE:
Acer Aspire One NAV50 screen blank
I am not in a position to offer free remote help, but you might help yourself with the link (below). It's to Acer's online community.
If this helps, you can indicate as much - g'luck.
http://community.acer.com/t5/2013-Archives/Acer-aspire-one-model-nav50-Drivers/m-p/57977#M39399
Jun 28, 2017 | Acer Aspire One Netbook
Blank Screen
Well it is possible to install a new screen relatively easily... It is a bit of a mission, Ya need to get a replacement screen & driver board and do the reverse procedure from removal. A screen can be got from say, Ebay, or the net. Otherwise get a reputable place to do it for you.
Jan 26, 2010 | Acer Aspire 3610 Notebook
Acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
Dec 19, 2009 | Acer Aspire 4315-2963 Notebook
Blank screen acer 4400
remove battery, press and hold power button for 5 seconds, then put battery back in and start.
This usually works. If by slight chance it does not, check that the memory cards aren't loose or faulty.
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3610 stuck in sleep mode
When you turn on your laptop do you see the P.O.S.T screen or it just remains blank? and also while booting up do you get any beep sound?
Try to boot your computer in Safe Mode by Tapping F2 (or Del in few laptops) key after pushing Power Button.
let me know what happens.
Askari :)
Mar 27, 2009 | Acer Aspire 3610 Notebook
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
The screen on my Acer Extenda 5610 is blank
I had the same problem with a vaio, it was the memory card.
I removed one (bad) card and it worked fine.
I hope this helps :)
Feb 23, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Acer laptop has black screen but power light is on
Does it appear to be doing anything. Is there a flashing "_" at the top left of your screen. If not try hooking a monitor up externally and turning the laptop on.
Dec 23, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
199 people viewed this question
Ekse
Alun Cox
