Question about A O Smith Motors Pool & Spa
I need wiring diagram for a.o. smith S#327P111, SER2C92
Replacement motor
    Top Expert:
  • A O Smith Mo... Master
  • 5,056 Answers
See side of motor for voltage wiring
Posted on Mar 30, 2016
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: Need to get diagram to wire gould century 1.5 h.p.
Email me at john@arrowmotor.net and I'll reply with the .PDF from AOSmith. You need to move a couple of wires but as they say, a picture is worth me typing a thousand words.
Posted on Aug 27, 2009
MOTORWIZJ
  • 1339 Answers
SOURCE: need ao smith replacement motor
a rebuilt motor is the cheap way $85 ,new around 200, the impeller will need to be ID to get the right size motor. search for your local pool pump repair guy with free motor testing, use your zip code in the search. you might get your old motor rebuilt and thats even cheaper .. CLEAN POOL IS A SAFER POOL .. VOTE COMMENT .. thanks jay
Posted on Aug 20, 2010
MOTORWIZJ
  • 1339 Answers
SOURCE: where to find replacement parts for AO smith pool pump motors
TRY YOUR LOCAL POOL PUMP MOTOR REPAIR GUY... NEW ARE HARD TO FIND AND CRAZZZY $$$ HE WILL HAVE GOOD USED PARTS CHEAP . IT'S THE GREEN THING TO DO. FIX -REPAIR.. GOOD FOR YOU, I'M PROUD OF YOU.. GOOD LUCK AND VOTE FOR ME...JAY
Posted on Aug 23, 2010
MOTORWIZJ
  • 1339 Answers
SOURCE: need to trouble shoot a C4SL2N134 pump motor. need wiring diagram
WD40 IS A WATER DISPERSANT AND WILL CAUSE MORE DAMAGE THAN GOOD ,IT WASHES AWAY OIL AND GREASE.. YOU MUST HAVE THE START SWITCH SET ,IT SHOULD BE CLOSED FOR START AND OPEN WHEN RUNNING.. NEW BEARINGS ARE THE ONLY GOOD FIX . YOU CAN TAKE THE BEARING IN YOUR HAND AT A SLIGHT ANGLE AND SPIN THE ROTOR, YOU CAN FEEL ANY BEARING DAMAGE THREW YOUR HAND I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Posted on Sep 11, 2010
Wiring issue
Without model info, try this link. Most motor brands follow pretty standard wiring setups. Please rate me if this helps.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Apr 16, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I look at the A.O. Smith Motor Master University manual and my question concerns the diagram on page 50, Single Phase Motor. In need to operate my motor with 115V and my understanding of the diagram is...
That is correct...if you have done that and still have problems post a comment that includes a description of what is happening and the motor model and serial number for further assistance.
John
Aug 25, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wiring new motor
I am assuming you are running 110 vac. Usually there is a diagram on the plate with the motor specification. You want the low voltage for110 and high for 220 motor wiring diagram you connect the motor as shown. If it is not on that motor it maybe on the old one they are usually the same.
You will need wire nuts to tie together the wires.
Note if this is a capacitive start or switch start. Allot of pool pumps are Switch start.
Mar 24, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Pool & Spa Logo
285 people viewed this question
Top A O Smith Motors Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Steve
Are you an A O Smith Motors Pool and Spa Expert? Answer questions, earn points and help others
