Question about Canon Power-Shot A2300 Digital Camera
How to adjust resolution on Canon DC1020W - Canon Power-Shot A2300 Digital Camera
How can i improve the resolution that i Scan photo's into computer?
The resolution can be adjusted inside the settings of your Canon Pixma software.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
My Cannon Pixma MP500 multi-function printer randomly scans only part of the document on the glass. Sometimes it does get it right; that is it correctly scans the whole page, but very often, the scan...
Try to adjust the scanner resolution
Solution: Adjusting Output (Scan) Resolution (Windows) - MP150 / MP170 / MP450 / MP500 / MP800 / MP950
Adjusting Output (Scan) Resolution By changing the resolution, you can set how clear the image is going to be.
The higher the resolution, the clearer (but the larger) the scanned image is.
The resolution can be changed before scanning. (Note)
If the resolution is doubled, the image data will be quadrupled.
If the data is large, problems such as slow processing speed or lack of memory may occur.
To change standard scan settings using MP Navigator, click here
To change more advanced scan settings using the scanner driver, click here
Using MP Navigator
  1. Place the document face-down on the platen glass.
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    Display varies according to the printer model.
  4. When the Scan Photo/Document window is displayed, click 'Specify'.
  5. When the Scan Settings window is displayed, select the resolution in Scanning Resolution drop-down.
    Select from the following scanning resolutions:
    [Text(OCR)]: 300/400/600
    Other: 75/100/150/200/300/400/600
  6. If necessary, set other items as well.
  7. Click 'OK'.
  8. In the Scan Photo/Document window, click 'Scan' to start scanning.
Using the scanner driver
  1. Launch MP Navigator.
  2. Click 'Scan with Scanner Driver'.
  3. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
    To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
  4. In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning.
Aug 13, 2008 | Canon Office Equipment & Supplies
Adjusting Pictures Resolution
you use the function button while in camera mode and scroll to the image size then turn the function dial to change it. you should consider taking your photos on the higest resolution, however, because SD cards are very cheap and you can get 8GB cards for under $40. Your camera came with a 32MB card which is tiny--you should throw it away. 8GB will store hundreds of 9 megapixel photos--i recommend having at least two SD cards. i hope this helps.
Mar 12, 2009 | Canon PowerShot SX110 IS Digital Camera
How to change Canon LBP2900 Printer resolution
Hi!
You do that in the settings for the printer.
Press start, select printer(s), select your printer, rightclick on the printer, select propeties.
There you will find all nessasary settings for your printer.
Good luck to you
Please take a minute and rate my answer
Nic
Feb 06, 2009 | Canon LASER SHOT LBP-2900 Printer
File size
Don't retake the photos, just resize them on your computer. Copy them to the system, My Pictures directory and use the photo tool to resize them to thumbnail. 2 minutes worth of work.
Oct 13, 2008 | Canon Digital Rebel / EOS-300D Digital...
Intalling camera software.
Greetings Shayy,
Generally screen resolution refers to your computers resolution which is controlled via the control panel of your computer. I would try fiddling with other screen resolutions to see if this helps. This will cause items on your computer to either be larger or smaller than you are used to, but you might find you like it better.
You would go to control panel>display>settings, to adjust this.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Canon Rebel xti vs Photoshop!
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon pixma mp830
go to this link first, 6 down will give you the latest drivers for your model; uninstall everything you have installed and start again; http://alpha02.c-wss.com/inc/ApplServlet?SV=WWUCA900 This link gives you all the various guides and manuals if you need them; http://alpha02.c-wss.com/inc/ApplServlet?RQF=MENU&RQS=WWUCA910&LA=1173934829986&SV=WWUCA900&menu=MA&TRF=MAIN Page 181 of the manual discusses problems with driver installation. Once you have updated the drivers, if the problem still occurs then check again in control panel - if you still can't change the resolution, then the problem is possibly with windows or the graphics chip/card is too basic - use the display troubleshooter in windows to see if there is anything you can do. Some older computers were limited in the resolutions they could display - if you can let me have the model number of the computer i can hopefully check for you. Hope this helps :)
Mar 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Power-Shot A2300 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
