Sc672 ricoh aficio mp301 - Office Equipment & Supplies
SOURCE: connection Ricoh Aficio 450 with computer?
hi im jules_09.use the copier cd installer when installing
Posted on Dec 11, 2007
  • 82 Answers
SOURCE: how do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Posted on Apr 06, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Posted on Jul 31, 2008
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
Error code is sc672 on display ricoh mp2550n
change the bicu board and the problem will be solved
Good luck.
Apr 05, 2014 | Ricoh Aficio 1013F Copier
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
We've a Ricoh MP3500 that is displaying an error code SC672 and directs us to switch the main power and switch back on. When switched back on, we have the same error code. Advice?
sc672 is a communication error between the controller board and some other component. Did you switch the machine off using the orange power switch on the lower left side, or just the power button on the operation panel?
With the power completely off and the machine unplugged, pull the controller board out by removing the two screws holding it in on the rear left side of the machine. (It should slide right out the side.) Check all of the connections on the board and make sure everything is sitting securely, then reinstall the controller board.
Worst case scenario, you might have a bad memory stick, bad controller board, or another bad circuit board, but more than likely there is a connector somewhere that just needs to be set securely. You can also remove the operation panel (two screws on the top of the panel and possibly two screws underneath it as well) and check the harness that connects the op panel board to the machine.
Jul 16, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh 1035
Jul 31, 2008 | Ricoh Aficio 1035 Copier
484 people viewed this question
k24674
jasbo
jasbo
