Question about HP PSC 2410 All-In-One InkJet Printer
Part I need the cover that clips above the black ink cartrige.
    Problem Solver:
  • 16 Answers
Parts are not available to fix this from HP or others. Either get one off a junk printer or junk yours and buy another.
Posted on Mar 01, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I have a full black ink cartridge but it will not print black
Hi
you need to clean black cartridge
the printhead of your cartridge is clogged
you need to try cleaning printheads from printer menu
or to replace it with a new one
but before that check expire date on cartrige
if it is old replace it or refill it only by using
refill clip in order to remove old ink
check here how you can do it
if i had help you pls vote me
Oct 27, 2010 | HP DeskJet F4280 All In One Printer InkJet
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
On my mfc 260C the black ink print keeps fading to nil but is ok each time for about 20 pages after pressing the ink management button. No problem ever with colour print.
You may need to run the cleaning fuction on your printer to clean the black print heads.
Every month (once a month), you need to clean your print heads to prevent your heads from clotting.
You are now seeing the symptoms of what happens when you do not constantly maintain your cleanliness of your print heads.
If that does not work, try buying a new black cartrige to see if the original black cartrige is defective.
If the above does not work, you may have a failing carrage and may need replacing
But do all of above first and get back to me with what happend during your diagnosis of your issues.
Jun 14, 2010 | Office Equipment & Supplies
Replaced cartriges with remanafacuter. Front
Try removing all 4 ink cartridges and unplug the power.
Close the ink cover, leave the ink cartridges out and then plug the power back in.
Once the printer boots up completely, reinstall the cartridges
Mar 26, 2010 | Dell 968w Printer
The ink cartriges wont fit into the printer.
This printer uses PG-30 and Cl-31 ink tanks. You can also use PG-40 and CL41. Open paper output tray. Turn on the machine and lift up the scanning unit or printer cover. Pull unit support down into place and the ink holder will move to the left. Gently remove cartridges and install new ones. Let me know of outcome.
Jun 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer does not print black & White documents
You just have to clean the printer head or change it.
Happend to me and solved it:
Open the top the way you use to change an ink cartrige...Unplug the power cord.. the ink tray will stay accessible.
Save your ink in some plastic wrap.
Just where you pull the ink cartriges is the head. Lift the little arm on right top of the assembly and pull toward you the black plastic kind of container..(for ink cartriges)..
that is where the head is attached. DO NOT FORCE anything..it should come easily.
At first place in warm clear water..use rubber gloves..often change water. When it looks quite clean..it is not. Unscrew the two littles screws holding the flat ribbon tip where the ink should go out..Beware...lift it gently..
underneat there is a small rubber part..just lift the end covering the black ink exit...Now pour all this in warm water mixed with Windex for some time and change the water till it comes quite clear. Now blow air from a compressed air can in the black ink canal..you will be surprise to see the amount of plugged ink coming out from there.Rince, dry with compressed air,screw back parts,place everything back and try an head alingment test to see your Black here again..
Apr 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
