Question about Zenith Audio Players & Recorders
Zenith Stereophonic Model Y962
How do I access the belt on the turn table?
  • lynn lavalette Feb 15, 2012
    do you have the owner's manual for your Y962? I'm looking for one. Also - do you have 4 speakers or 8 speakers in your console? Mine only have the 15" woofers and the 4" X 6" horns so I'm puzzled as I thought there should be 8 speakers (I have manuals for 1968 (X962) and 1969 (ZT960) and both say 8 speakers. Feel free to email me LynnLav@aol
    I also have the schematics for this turntable so contact me...
4 Suggested Answers
emissionwiz
  • 77186 Answers
SOURCE: Need needle for zenith stereophonic
The best place to get a replacement is from any Radio Shack electronics store. You can also get needles on line.
Posted on Jan 17, 2011
gopakumarg43
  • 74630 Answers
SOURCE: I have a zenith model 73326 how do I operate the
Just download its user manual by this site. www.retrevo.com/
It has all details. http://electronicshelponline.blogspot.com/
Posted on Oct 24, 2014
claudeinmo
  • 9098 Answers
SOURCE: I just picked up a Zenith Solid State stereophonic portable turntable. When I turn it on it makes a humming sound. How can I fix it? The model number is NPS40. Thanks, Karen
How To Fix Turntable Hum - Best Turntables
best-turntables.com/how-to-fix-turntable-hu/
Turntable hum refers to the constant electronic humming or buzzing noise that occurs when the amplifier is set to the input the turntable is on.There's nothing ...
Posted on Oct 20, 2015
Why doesn't my turn table turn?
If this is about a record player then I would check the belt. You will have to remove the platter to get to it. Some platters have holes in them for accessing the belt without removing it. To see which you have you will have to remove the mat on the turntable.
Dec 29, 2014 | Saws
How to install;drive belt on model 34-670 saw ?
You must lower the motor down as far as possible and then tilt the saw blade so the back end of the motor where the belt is housed is exposed and accessible as possible. Then remove the cover housing at the back end of the motor. This will expose the belt. Thenyou can remove the old belt and install the new one.
May 19, 2014 | Saws
Zenith model b835e
Hello, I'm sorry your 1956 model b835e radio don't have an auxiliary input. There were other models that had a turn table input, but not that one....sorry....tks
Nov 09, 2013 | Televison & Video
Vintage Audio Repair in the NYC/NJ area
The hum is a tube that has gone weak or a volume switch that may be going out! Try a TV repair shop in your area, and call first so they can tell you if they are familiar with the old equipment!
Oct 21, 2013 | Audio Players & Recorders
I have a Zenith Allegro Console with a turn table and it spins to fast. Are there any adjustments I can make?
It depends what kind of drive this model has. It's possible that since this is a model that has the 78rpm speed it could use the old type of drive. If so then what happens is that a mains powered motor has a three position pole on it. A rubber tyre presses on each section on the pole. The speed switch manually moves it up or down. The tyre presses on the motor and on the rim of the platter. A worn tyre or one that is not moving to the right section on the motor will cause incorrect speed.
The only other form of drive would be a belt, but not many belt drive turntables were built with the 78 speed of this date.
Sep 22, 2013 | Audio Players & Recorders
Need needle for zenith stereophonic high fidelity
Jan 17, 2011 | Audio Players & Recorders
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
Flat screen stand for 16" Flat Screen Zenith
fit it to the wall or go on ebay serch "table top stand zenith"
Nov 04, 2009 | Televison & Video
10'' bench drill press model DP200 WON'T START
The belt has either come off the pulley or the belt is slipping. Open th top access hatch and check the belts . If belt is off replace and tighten , if it is just loose tighten the belt.If it is not the belt and the motor is humming but not turning you will need to replace the motor's starting capacitor.Good luck and please don't forget to rate this answer, Thanks
Apr 11, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
172 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
