Question about Kitchen Appliances - Others
How to operate an induction cooker, inextron
The induction cooker has buttons for heating, temperature and time and i want to know what should be the setting when i boil rice, for example
SOURCE: Spoiled rice after 20+ hours
Our rice cooker would keep the rice from spoiling for about two years and then all of a sudden it wouldn't keep for even 12 hours before the "spoiling" smell would be present. I tried really washing every washable part and even did an alcohol wipedown in case it was a bacterial or something, but nothing worked. I liked the cooker before this started happening, but don't want to buy another one because it is so expensive. When I was in Japan, there are some REALLY good ones that would monitor the moisture level and want one of those, but will have to live with what is available here. Anyone got a solution?
Posted on Mar 29, 2008
ginko
  • 19396 Answers
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
Posted on Feb 27, 2009
KMusselmann
  • 247 Answers
SOURCE: need instructions for assembly, proportions water and rice (brown & white), cooking time, how to operate
Here is a users manual. Hope this helps
Pls rate the answer
Kurt
http://kitchen.manualsonline.com/manuals/mfg/salton/ra3.html?s=fpw
Posted on Apr 20, 2009
pabloloco
  • 2335 Answers
SOURCE: Rice Cooker Instructions
For Queenmom and anyone else looking for the manual for a Black and Decker Flavor Scenter Handy Steamer Users Manual, I just stumbled across one. Here's the link:
http://useandcaremanuals.com/pdf/HS90038.pdf
I hope that helps.
Posted on Sep 19, 2009
SOURCE: My oster 3071 rice cooker ''E2'' error
it happened on my oster 3071 the error e2 just appear the only that i did was open it and I found out that the blue wire which is connected on the lid is cut so i just reconnect the wire and stick it together using souldering iron and presto it is good as new again
Posted on Jul 23, 2010
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Induction is on but when i press start button than start and agin off
Check weather you are using correct size and material of vessel .some simple test is use a magnet to check right vessel.
Non magnetic material will not heat.
Nov 15, 2013 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
I have a prestige Induction cooker... a new one. When I tried to turn it on for first time, it just shows "-- -- -- --". Post this, even after placing a induction cooker compatible vessel, it...
We have a Prestige Induction cook-top Model PIC 3.0. It gives the error "-- -- -- --" and a beep when the power is turned on. Can anybody help. My email is asbhambra@gmail.com
Mar 11, 2011 | Microwave Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
I dont know how to use induction cooker.it has no numbers to reduce the heat.things will burn very fast
You can use to set the timing in order of the heat required. Also using the grade rating of the heating coupled with the time set, the food can be easily heated without burning.
To start with use low heat and long time, the try with medium heat and lesser time and then choose high heat and short time. You must be able to use the settings accordingg to your requirement.
Hope this advice helps
Aug 27, 2010 | Microwave Ovens
Vollrath induction cooker is not working. The display reads F9. Model # is 59500.
The range does not recognize the pan material. Only ferrous (magnetic) cookware will work with induction. This is a protection circuit to only heat proper cookware. When all else fails read the instruction book or call the service department for the manufacturer...save time, reduces frustration and assures safe operation. Good Luck
Apr 18, 2009 | Kitchen Ranges
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
