Question about Marantz RC006SR Remote Control
Volume high is not working
Volume + is not working
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
Bose speaker service
If the speakers are making a crackling noise at high volume yes, you need to take them in for service. The main problem that I have found to cause this issue is faulty instillation from the factory or using the system at a high volume with music. If it were me, I would send them in to Bose. They are a great company and will work with you to fix the issue.
Aug 17, 2012 | Bose 301 Series V Direct/Reflecting...
Sound only works at high volume
What happens in a lot of these sets is the speakers are tiny--they get used long enough at fairly high volume and the paper in the speakers can tear or even come apart---if able a look inside at the speaker/s would show if this is the case.
Jun 16, 2012 | Philips 27PT9007D 27" TV
I am using a new siemens desk telephone. I dont know the model number & they dint give me the manual. I just could not reduce the ring tone volume. Any help on this is highly appreciated. I am...
Just look at the bottom of the phone, you will find ringer tone volume marked with low & high. Put it to low. For the manual, see the bottom-side of the phone to locate the model number & search the Siemens website for the manual.
sonunny
Jun 30, 2011 | Cell Phones
THE U &L SOLO PANEL PLAYS VERY LOW NO VOLUME YOU CAN HEAR IT VERY LOW WHEN VOLUME IS SET AT HIGH AND SWELL IS AT HIGH ALL WORKS JUST NO VOLUME
Who would have any idea of what make or model device you have? Sounds like some brand of organ. We are not mind readers on this forum.
Oct 14, 2010 | Music
I have a passat 3.6 2006 that is driving me crazy whith the volume that i cannot control as i would like to.I already have deactived the speed control and that problem still there,if want the volume high...
The radio's in most VW's are fickle. You basically need a new unit. Whatever you do ,do not buy one from the Dealer. Any other models are cheaper and will last and work better than the factory unit.
Jun 23, 2010 | 2006 Volkswagen Passat
The volume stays on high. I can lower it but, after I release the button the volume goes back to high.
I have the same problem with KV-20-FV-300. My remote stopped working and when I adjusted the volume manually, it goes to high and when it adjust it back down, it goes high again. I'm able to get the sound to stabilize by getting the volume to where I want it, and then pushing the up and down volume buttons at the same time. I'm still searching for a permanant solution though.
Mar 20, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
They are makeing a constant sharp noise a loud high pitched hum if you will
Right-click on the speaker icon in the lower right of your screen and choose Open Volume Control and check all volume levels (make sure they are not set to high). If this doesnt work then when you right-click, choose Adjust Audio Properties and search around for volume controls (maybe try the Speaker Volume button).
Aug 04, 2009 | Audio Players & Recorders
Realtek High Definition Audio
Nope you can still use Volume Control while Using Realtek High Defnition Audio. i'm using Realtek High Defnition Audio too and Volume Control work find to me on any OS installed on my computer
Jun 30, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Sound form Bush TV
It could be several problems, I'll share with u a couple. All of them need a tech.[technician]
Your volume control works by adjusting the voltage\current to the speakers. The VOLUME CONTROL could be damaged\fixed at a point [even if you are raising\lowering] at high volume.Sometime the control has a crack ********\********* in such a way that the volume arm won't go past crack[see above] on HIGH volume.
The audio IC could be shorted in high volume. Sometimes the audio IC is PART of a 64 (sixty-four) pin ckt. How do u test for that if u are not a techo'
Let someone take a peek at it.
Oct 23, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Marantz RC006SR Remote Control Logo
81 people viewed this question
Top Marantz Televison & Video Experts
Electro Med Services...
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
