Question about Promise Computers & Internet
Fasttrak s150 recovery - Promise Computers & Internet
I have an Intek DG45ID motherboard, installed a Fasttrak TX4650 RAID card in the PCI-X x1 slot. The motherboard does not get past the BIOS post in the boot process, just after showing the boot options a...
It seems that the card might be faulty. If there were incompatibility problems, they would normally show up under the operating system (Windows, Linux, etc), not during the booting process.
From your description, I suspect that the card's BIOS is corrupt. Try getting a replacement under warranty and see if the new card works normally (it should).
Mar 13, 2011 | Promise FastTrak TX4650 4 Port SAS RAID...
My Tashiba Lap Top a45-s150 is corrupt. WINDOWS/SYSTEMS32/CONFIG/SYSTEM. I bought a recovery disc but my computer only goes to this black screen. Help?
For that you need to repair your windows.
Insert recovery disk into cd/dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios .
Then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boor with recovery disk follow the procedure and choose Repair option for repair windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 07, 2010 | Toshiba Computers & Internet
Toshiba A 45-S150: How to boot from external dvd drive?
Remove the disk-drive from the laptop, and connect it to another computer.
Copy all the files from the recovery-media onto the disk-drive.
Reinstall the disk-drive into your laptop.
Run the recovery software from where you copied the files onto the disk-drive.
Jan 01, 2010 | Toshiba Satellite A45-S150 Notebook
Promise FastTrak TX2300
You will need to download the drivers on to a floppy disk. When loading setup press F6 when it asks if you want to use third-party RAID controller.
You can get the drivers from the below link
http://www.promise.com/support/download/download2_eng.asp?productId=136&category=driver&os=0&go=GO
Oct 25, 2008 | Promise (FASTTRAK TX2300-5PK)...
New Hard Drive, system recovery problem
The systems disc is for the drivers and utilities, and, yes, there should have been two discs with the machine. The A45 is new enough that it should have come with an XP disc, not 98. I believe there was a mix up and you have the wrong disc. If you can get the operating system to load with the recovery disc you have, then you can get the drivers at the link below. Some two disc sets will not load an operational system unless you have both discs. Since you were running XP before, I don't think you're going to be happy with 98. I'm going to suggest that you purchase an XP disc, or contact Toshiba, and let them know that the wrong disc came with the machine, they might send you the right disc. If you do have to purchase an XP disc, simply load the system, then go to the link bellow and download the drivers. If you need any further assistance, feel free to ask.
Aug 14, 2008 | Toshiba Satellite A45-S150 Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
RAID 0 Array disappeared after reboot
I would try the hard drive on another sata controller/port to verify that the bad drive is in fact bad. If it is really bad, then no there is nothing you can do but replace the drive and recreate the array (losing all data!).
You can not 'recover' a failed RAID-0 array because there is no parity or mirror data on an extra disk like there is with the other RAID modes. This is why people recommend against using RAID-0 for important data (unless you take frequent backups): RAID-0 actually increases your likelihood of losing your data. Statistically speaking, you are multiply the failure rates of each individual drive together.
Dec 22, 2007 | Promise FastTrak S150 TX2Plus Serial ATA...
Computers & Internet Logo
29 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
C. David Graves
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
