Question about LG 47LS4500
My picture wont resize to fit the screen, some of the picture is being cut off.
It is fine through cable but not when hooked up with HDMI
2 Suggested Answers
  • 401 Answers
SOURCE: Lg TV picture is purple when trying to hook it up
It could be anything. Have you tried checking that you have everything properly connected; I.e. sometimes you might have connected something wrong. Or make sure that both devices are compatible with each other. Or maybe you're just using the wrong cable/cord for the job.
Posted on Nov 13, 2012
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
I am trying to hook my ps3 up to my Hitachi 65 s500. I have the hdmi cable to hook up to imput 1 but when I do that The screen is showing fuzzy color but no picture. What am I doing wrong.
Make sure you're hooking it up to the HDMI port or the Composite port correctly. There is a red green and blue for composite that usually wont work in a port marked "Input 1" You would need to put it in "component/composite 1" correctly. I've come across this not working in 1080, but fine in 720p.
Jun 07, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
The picture is too large for screen and is cut off on top and bottom. Possibly on the sides too.
There is a button the remote control that will resize images. However this could also indicate that a tv is in the wrong input and or connected to the set top box (ie cable box or satellite receiver) incorrectly. It can also indicate that the set top box is set to the wrong resolution.
Buttons on the remote control could be view mode, aspect or format, and # hd zoom.
The tv could be in the input for the rf connector or the composite cables instead of being on the input for the component or hdmi cables.
The tv could be connected to the set top box with RCA cables or a coax cable instead of being connected with component or an hdmi cable.
Apr 28, 2010 | Televison & Video
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Turns on fine no picture on a diferent TV
Hi, i have had to solve this problem in my own home. You must have access to some HDMI output to fix this. the playstation 3 does not have auto-detect like the xbox 360. meaning if you have an hdmi then switch to standard AV, the system wont detect this. you need to hook up the system to an hdmi output, then switch the settings over to the AV output while both sets are plugged in. if you need more clarification feel free to email me! gungraveislife@gmail.com
Mar 16, 2009 | Sony Playstation 3 (PS3) Console
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Mitsubishi WD-52631no picture through the HDMI connections
had the same problem get a new cable its not the tv its the ps3 if the cable is tight in the ps3 it works fine or if you set the ps3 just right the cable will fit fine and work
May 24, 2008 | Mitsubishi WD-52631 52" Projection HDTV
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
How do I set my HCN4226W for 1080i?
I don't think the set will allow resizing in DVI mode, at least mine never has. I have to switch to the video input or S video to get that to work. I think there is something in the manual about that. On mine, the component input will not work if you have the DVI connected. If you have DTV, try resizing the image on the satellite receiver's remote. Sometimes, in the DVI mode, that works. I am about to pitch this set of mine out, as it now has fried something in the convergence system and won't work at all, so if the new convergence board I have ordered wont fix it, its going up on Ebay for parts !
Jul 29, 2007 | Samsung HCN4226W 42" Rear Projection...
LG 47LS4500 Logo
24 people viewed this question
Computer Repairing
Computer Repairing
