Hotpoint model vbxr1090dbww will not agitate. However, will drain and spin. Any ideas, please?
  • gayleheisler
    gayleheisler Feb 06, 2013
    If you have figured this out i am having exactly the same problem with the same model would love to know what to fix.
    Problem Solver:
  • 19 Answers
Check to see if there is a broken belt. if the belt is ok the transmission may be bad
Posted on Jan 17, 2013
gwshaw71
  • 83 Answers
SOURCE: VBXR1090DBWW top load wahsing machine
your problem is your lid switch
Posted on Dec 07, 2007
SOURCE: Kitchenaid Washer Model #KAWS700JQ4
Washer has a motor coupler linking motor to transmission. If this motor coupler is broken or has rounded out where it engages the motor and/or transmission gear it will only fill and drain. You can view this coupler by leaning washer back against the wall & looking underneath with a flashlight. There may be a sound dampener panel on the bottom that you have to remove to see it. It is two pieces of white plastic with a rubber grommet in the middle.
Posted on Dec 16, 2008
Oceti
  • 51 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
SOURCE: Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Posted on Jan 22, 2009
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
Washer won't agitate it does spin the clothes
Hi
If Washing machine wont agitate there are several reasons that causes such problem,please check the bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntagitate
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint VWSR4150B Top Load Washer
Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
My washer will fill up and drain but not agitate or spin
Looks like the motor needs to be replaced. After some years of use, the motor may not have enough strength to move the drum. If you test the motor by itself, it may work, but can't handle a load.
Sep 19, 2009 | Hotpoint Washing Machines
Fills, does not agitate, drains, spins, fills, does not agitate, drains, spins
grab the agitator at the base and give it a quick push upward..remove and see if the white dome with bolt holding it down is stripped on the inside where it splines onto the transmission shaft. :)
Jun 13, 2009 | Hotpoint VBXR1090D Top Load Washer
No agitate/no spin/yes spin in rinse
this is a drive shaft issue. this shaft is connected to the gear case and the gears may be stripped or the clutch may be damaged. there are many plastic parts here in this area that can break due to heavy load or just old age. replacing the internal parts and clutch will fix these issue you are having.
Mar 13, 2009 | Hotpoint VBSR3100D Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
