Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
My kv 36xbr800 blinks 6 times, no picture or sound. Does anyone know what is the issue.
Does it pay to repair
    Top Expert:
  • Sony Master
  • 34,255 Answers
Power supply trouble
Posted on Jan 17, 2013
4 Suggested Answers
SOURCE: Sony TV KV-36XBR800 blinks 6 times, pauses, blinks
If it's any comfort we are having the same problem
Posted on Jan 16, 2010
welcomejee
  • 10594 Answers
SOURCE: Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Thanks.
Posted on Sep 22, 2009
  • 61 Answers
SOURCE: Sony KV-36XBR800 won't turn on and red led on the front blinks 6 times
For 6 blinks Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.I think this will help you to solve this issue..
Dont forgety to Rate!!
Good Luck
Dals123
Posted on Oct 22, 2008
Light blinks 7 times when i try to turn it on. sony kv 36xbr800
Are you sure it isn't eight......try turning on this method....display, 5, vol+, power on. Should bring it on in the diagnostic mode. Mine and about kazillion other owners have the same problem, bad M board and they never issued a recall on it. Costs 2-300 to have someone repair it, cause its' too heavy to carry it in, I think they used cement in the bottom for weight.
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 36xbr800 shuts off on own
sounds like one of your color tubes or a system board is failing and will have to be tested and replaced by repairman
Feb 11, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 36XBR800 Standby light flashes ...no picture sound
For 6 blinks,Pls check following area.
Low HV Shutdown:
On the D Board.
I think this will help you to solve the issue.
Dont forget to Rate!!
Good Luck
Dals123
Apr 10, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
