Question about Onkyo Tx-nr616 7.2 Thx Certified Network Receiver <<< Pre-order >>>
Onkyo TX-NR616 the hdmi video out is not working. what do i do to fix it
Working fine until now. 3 weeks
jeesusfreek
  • 18 Answers
SOURCE: Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Posted on Jan 28, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
SOURCE: Onkyo TX-SR606 HDMI output issues
HDMI switching is an ongoing problem for the 606. A number of people are having the same problem. Mine is at the local repair shop and Onkyo has told them the part is on backorder until April. I would look at another brand or upgrade to a higher leval Onkyo.
Posted on Feb 03, 2010
SOURCE: HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Posted on Apr 30, 2010
Set my mac to the receiver
Hello Clifton booker, You would need to run an HDMI cable from the MAC to the receiver. Thanks, FJD
May 30, 2016 | Onkyo TX-NR616
Why cant i get sound to come out
HI
since when you have this unit ?
when did this problem started?
the more information is better so i can help you
Regards
Apr 24, 2016 | Onkyo Tx-nr616 7.2 Thx Certified Network...
I have a onkyo TX-NR616 receiver which has now for some reason has no sound when fist switched on, however if left on for about 15 minutes then turned off and straight back on again then after a few s
There is an extended warranty coverage that Onkyo is providing on receivers manufactured between 2009-12. Not sure if the TX-NR616 is included, but here is a thread from the AVS forum on the problem:
Onkyo acknowledges failed units and extending warrranties until 2018 AVS...
Feb 07, 2015 | Onkyo Audio Players & Recorders
Onkyo tx-nr616
harder to do but you can probably still use the display on the unit.
I am unfamiliar with the onkyos but am often setting up integras which are basically onkyos.
Find the setup button on the face of the receiver. It might be called different things but basically you will call up the settings and use the arrows - enter - and return to navigate in and out of the menu options.
Integras have that will allow you to;
configure connected speakers
- sub yes-no
- center yes - no
- rear surround yes-no
- speaker size small-large
input config (mapping audio, video connections to the input names)
ex:
- "Cbl/Sat" -> HDMI 1 - 4
- "BD/DVD" -> HDMI 1 - 4
etc.
You'll get the hang of it.
OR - do you have a small TV with a composite video connection?
I carry around a portable Coby battery powered monitor that has a composite video input for these types of problems. Composite video is always active.
May 26, 2014 | Onkyo TX-NR616
Onkyo receiver is not starting up hdmi from receiver to tv
run an HDMI cable from TV direct to DVD or other HD source instead of going through Onkyo. If it works, you have a bad HDMI output on the Onkyo. If not you may have a bad cable or a bad port on TV. Then try a different HDMI input on TV.
Jan 15, 2013 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Need Onkyo tx-nr616 remote code so ATT U-verse remote can control Onkyo
I used 5002 and it works for on/off only. This is better than nothing. You can try codes from other Onyko devices to see if you can get one that provides more functional control.
Dec 31, 2012 | Onkyo TX-SR705 Receiver
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
manual
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Tx-sr606. Signal lost to TV on HDMI Out. Coming in from Component Video or DVD or Game Components. Audio is playing but I get no signal to TV. HDMI Cable is fine. usually have to turn it off or unplug...
Check the most popular solutions.Also check that if you give the receiver some time (in my situation at this moment about 10 minutes) after you turned it on an selection of source.
I just received the new capacitors from a German store and will install them 2 weeks from now.
Rgrds,
Phil
Jan 25, 2011 | Onkyo TX-SR606 Receiver
The HDMI is not outputting to my display. I have 3 inputs and none of them work. However they did work for about 2 weeks with no problem. I can take the input directly to the display and they work...
Measure all hdmi inputs and output HPD Voltage by a needle probe.
Steps:
(1)unplug the amp.
(2)open the cover.
(3)connect a blu ray player to hdmi input & a mon to output, otherwise no 5V.
(4)negative probe connected to the large heat sink with large power transistors mounted by a crocodile clip.
(5)postive probe to right hand side last pin called hot plug detect, HPD.
(6)If it has 5V, hdmi board is OK. Check HDMI cables(7)If no 5V, check power to this board. Go to you tube:How to fix an Onkyo receiver - TX-SR606 . All large capacitors next to SMPS IC are replaced.
(8) If not OK, replace Q 8595-Q8597.
(9)If not OK, replace Q8501,sil9135.(Onkyo won't help you to replace this HDMI decoding Chip. A HDMI board replacement instead, the company policy.)
Oct 02, 2017 | Onkyo TX-SR605 Receiver
No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Jul 03, 2008 | Televison & Video
Onkyo Tx-nr616 7.2 Thx Certified Network Receiver <<< Pre-order >>> Logo
236 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
