Question about Baumatic BTWM4 Front Load Washer
Baumatic btwm4 washing machine wont rinse and empty
Put the programme on 3 it gets to 4 and stops. it looks as though it washes up to that point and then just stops. cant find a reset button on back ( as seen in another post ) tried to put another programme on say 7 and it starts to turn and looks as though it is going to work but then stops again. please help if you can dave
If it wont empty its either a blocked pump/or filter. If it won't move on, heating element
Posted on Jul 11, 2007
SOURCE:
I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Apr 23, 2012 | Baumatic BTWM4 Front Load Washer
All the cycles are working but the washing machine will not rinse the excess water left. I have tried to take out the filter but this is stuck and will not move so the water sits in the washing machine. ...
Do not run the machine until you have cleared the filter or you will burn the pump out. You need to keep working the filter until you are able to get it opened and cleared.
Dec 31, 2010 | Baumatic BTWM4 Front Load Washer
I have a Baumatic BTW M4 washing machine(4 yrs old). It wouldn't empty now lost all power to machine. cleared blocked filter changed fuse to plug etc still no power lights. is there a reset button etc?...
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is a generic service manual, use this to troubleshoot your unit.Below is your user manual, for Codes etc. http://www.manualnguide.com/manual-get/12342/
When they do this, usually it is the "Brain" or a Sensor, that is inhibiting it from working, use the manuals and maybe you can sort it out.
May 01, 2010 | Baumatic BTWM4 Front Load Washer
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Feb 10, 2009 | Baumatic BTWM4 Front Load Washer
Baumatic washing m/c btwm4
check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Nov 25, 2008 | Baumatic BTWM4 Front Load Washer
Baumatic washing machine not heating (BTWM4)
ohm out the element if it shows no continuty then replace it
Mar 25, 2008 | Baumatic BTWM4 Front Load Washer
Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Jan 11, 2007 | Baumatic BTWM4 Front Load Washer
Baumatic BTWM4 Front Load Washer Logo
376 people viewed this question
Top Baumatic Washing Machines Experts
jimorris77
TriciaGirl
Level 1 Expert
Marvin
Marvin
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
