Question about Jandy AQUALINK RS TELELINK KIT
I have an Aqualink RS6 system everything works fine in all modes with one exception. When the outside air temp drops and activates "Freeze Protection" the pool pump cycles on and off instead of stayi
  • jeffander66 Jan 19, 2013
    When the air temp get to the freeze protection setting 36 degrees , the pump comes on for a second then shuts off. Comes on for a secondand then goes off. as the temperature dros, the pump stays on a little longer beforeit stops. The constant start anstopping of the pump cannot be good for the pump. If I put the sensor in ice water, the freeze protection comes on and stays on!
  • jeffander66 Jan 22, 2013
    The constant cycling (banging on and off) cannot be good for the pump. If I stick the sensor in ice water it will turn on and stay on without cycling I don't think the cycling is normal.
    President:
  • 2,976 Answers
It sounds like it is working properly.
Posted on Jan 18, 2013
2 Suggested Answers
  • 990 Answers
SOURCE: Freeze protection is activated on
You don't adjust this. You will need to replace the air sensor. You can get the sensor at or through any pool shop and it is simple to replace. You will find it hanging under your box by the equiptment, or somewhere close in the shade. Follow the wire into the box and find the terminal block it screws into. You will need a tiny flat screwdriver for this. Remove the old one and install the new one, close the box and your done.
Posted on Sep 04, 2010
Freeze protect drops to -20 degrees
need new air temp sensor trade on board with water temp see if it reads different if not need new PCB board
Feb 06, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool spa heater when freezing temp
It normally will heat up with pump moving water, once the threshold is achieved - system will come out of its Freeze protection mode and will begin to work as programmed. If there is a heat call, heater will come on.
You can also locate the sensors, both the Water & Air (they need to be very close in temperature for this to work) then place them in water warmer than the actual ambient temp, & above the temp that triggers "Freeze".
Dec 27, 2012 | Jandy Aqualink Rs4 One Touch Control...
My RS6 all button is blinking, but pump still comes on as scheduled and can use buttons for other functions except heater wont fire. Outside unit display says Err. Diagnostic codes say 8157 Rev L and...
This issuesounds tricky. I recommend you call the Jandy technical support at 800-822-7933and they should be able to help you figure this issue out. Ihope this helps.
Sep 18, 2011 | Jandy Aqualink Rs4 One Touch Control...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
May 21, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I do have a problem with Jandy Aqualink System
I would lower the freeze setting. It sound slike you are hovering around the temp set for freeze and that is why it is turning on/off. Go into the freeze mode settings and lower it as you would a heater setting.
Dec 28, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Auto shut down function not working (Jandy Aqualink RS6)
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Nov 24, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
222 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
