My screen would open when i first got it then couple months later it stoped opening i can only use the buttons to play radio can somone plz help me would be such big help tyvm :)
SOURCE: want dvd to play while driving its played before i hit reset button now it does'nt play
You need to hook up the pink wire to a power wire. I myself have a switch in my cig outlet (which ran blue lights i had inside my car) running it so if i ever got pulled over i just pull out the switch and they cant prove i was playing a movie.
SOURCE: my phase linear uv7ts wont come on at all
check your ground connection and all wires for loose connections.
match wires according to color.
SOURCE: my phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
SOURCE: phase linear uv8020
To change the region code on the UV8 you must have a dvd playing and 1. with the remote press setup 2. then enter 5, 4, 3, 2, 1. This gives you access to firmware menu. 3. arrow down to tools "system settings" (you should be able to use the touchscreen) enter on region a menu opens and select "0" to make it region free. You can also go down to the brake bypass menu here to to put in "off" mode so you can see movies while driving.
SOURCE: i need a remote for my jensen phase linear uv8
Get one off of ebay. Just received one for bout 30.00 Good luck
