Question about TruTech PVS12701 Portable DVD Player
Screen says "no disc" when there is a disc
The screen says no disc when there is in fact a disc inside. it does not spin when i load it, says "loading" then straight to "no disc". i have cleaned said disc. have switched said disc with the same response. it is not reading any disc i put in, nor is it spinning. it is just under a year old.
  • 98 Answers
Has it ever spun and do music cd's work cheack the regon number on the dvds and the player
Posted on Jan 24, 2009
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
The cd player do not spin it comes on then go off
Hello
The sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
Jan 05, 2012 | Lenoxx Electronics Audio Players &...
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
After loading I get either No disk or Wrong disk. Very rarely display works, mostly it keeps spinning with loading on. I tried DVDs, CDs. Same. Cleaning laser did not help. Thanks for assistance....
Hello
You haven't specified nothing about the model number or brand name of you player. Yet i posts this solution, as a common fault symptom. From your description, I assumes that either Laser Picku Unit or Sled motor is faulty. Sled motor is one that spins the disc inside the player. Just open your players outer cover, insert a disc and see whether it spins as it loaded or not. If not replace the sled motor. If it spins, and the Laser Pickup Unit attempts to read the disc from its inside edge to outer, and fails to read the lead-in and lead-out data from disc, laser assembly is faulty and should be replaced with an idetical one both in type and number. In some cases, the strip wire that connects the laser unit to main board may get braked connection prints inside it, which cammot be detected easly. First of all replace this strip wire, and see the effect if disc spins as i indicated earlier. If you wants furthermore assistance, give me a mail, and indicate your need, as I may forget about the solution which I posts to you. gopakumarg43@ymail.com. OK.
Feb 03, 2011 | Televison & Video
Every time I put a game in it will play for a good while and then all of sudden it will say, problems reading disc check owners manual, or something like that.
This is not nessesarily a solve issue, however it worked with mine, I had the same issues when playing games. I would be in the middle of gameplay, and the the error screen would pop up and say that the disc coudnt be read, All I did to fix the issue was open the unit, blow the dust off the disc drive motor and attatched ****, then I used some 3 in one oil on all the motors inside the system. So far it hasnt messed up (FINGERS CROSSED) I hope this helps.....I noticed with my gamecube that it would quit spinning the game, and after I made it past the gameplay loaded in memory it would error out because it needed to spin the disc and load more programing into memory.....if your disc dont spin you are guarenteed a disc read error
Sep 26, 2009 | Nintendo GameCube Console
Device could not see CD. it's TDK disc with come MP3.
Hello
Look whether the CD spins inside the set, after it has been loaded well. If not replace sled motor. Sled motor is one which do spins the disc inside. If disc spins inside, and the set do not read the disc, laser pickup unit is faulty, and should be replaced with same type and number. OK.
Aug 01, 2009 | Sony CMT-NE5 CD Shelf System
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
TruTech PVS12701 Portable DVD Player Logo
281 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
