Question about Ott lite Ottlite T81g5t Wing Shade Visionsaver 18-watt Floor Lamp Black
I need ballast for a ottlite
Need a replacement ballast
Where are the brushes as need replaced?
If your brushes need replacing, they are within the motor, inside the cleaner. Unless the cleaner is old, say more than 5 years, or has been used very frequently, I would be surprised if the brushes need replacing. What symptoms do you have?
Jan 04, 2016 | Vacuums
My brand new ott lite will not turn off. what am I doing wrong
Get in touch with Ott Lite at: http://www.ottlite.com/t-customerservice.aspx
May 08, 2015 | Ott lite Ottlite 759803 Task Lamp Blue
I just replaced the clutch on dyson dc07 and it's
Hi there, Yes it likely does need replacing. The only other possibility is that the base plate is installed slightly incorrectly and is pressing on the roller making it unable to move. If the machine makes the same sound without the base plate on replace the roller brush. It is possible to simply replace the roller brush bearing too (size 625) if the roller is not damaged.
Mar 12, 2012 | Vacuums
I put brand new T8 light bulbs in a fixture but the lights are still flickering is it the ballast.
Are they actually flickering on and off?- or just sort of Twirling patterns of lighter and darker shade of light? -- That is normal when the bulbs are new-- That should become steady in a few days.
If not-- tell us more what is happening-- in detail.
Mack B
Dec 28, 2010 | Vacuums
The on/off switch doesn't work on my floor lamp electric trait # PL/F 27W 6500K UL. E224694 Is there a replcement for it or is there a repair place here? Cary, N.C.
Suggestion: Someone just might want to peek inside the Electronic Ballast Enclosure mounted within the unit's base when they have the time and inspect for signs of failure similar to what I found in mine before insisting on buying a New Switch and risking disappointment first-cut. Burnt components are a dead giveaway, as (usually) is a blown fuse, although there's nothing wrong with jumpering that fuse to see what lights-up again or smokes, atcmb.
Those little snap-in SPDT switches are really rather rugged - your unit just MIGHT have a defective switch and nothing more - but I for one do tend to doubt that notion. Best double-check first before ordering.
Sep 13, 2010 | Vacuums
Rechargable batteries need to be replaced
you may not need batteries just a new charging plug. if the batteries are damaged all you need to do is replace the handheld part of the pronto, this is where the batteries are located.
Jul 09, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
Need to replace the suction hose, need help reattaching
You need to purchase a new hose - you can search for it online (DC07 External hose) or you can simply call the Dyson helpline and order it through them.
Jul 13, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
Ott lite Ottlite T81g5t Wing Shade Visionsaver 18-watt Floor Lamp Black Logo
Top Ott Vacuums Experts
JoeVacs
Are you an Ott Vacuum Expert? Answer questions, earn points and help others
