Question about Kenmore Washing Machines
Kenmore 110-27831600 Top load machine works fine until final spin. Water pumps out but there is a loud roaring sound and it will not spin. Replaced clutch and break but still same trouble.
  • elainetholen
    elainetholen Jan 17, 2013
    It ended up being the motor coupler, which was stripped out. Also replaced agitator dogs. Works great now. Thanks for the responsed.
  • elainetholen
    elainetholen Jan 19, 2013
    Replaced motor coupler and agitator dogs and works fine now.
  • Kenmore Master
  • 17,130 Answers
Possible that there is no free movement of the spindle and drive. You must check for the free movement manually with you hand- switch off power when doing so.
If the spindle is tight then the assembly must be removed and reset.
Check the action of the brakes, if this holding on you can remove to test and then reset. check the motor movement.
Posted on Jan 17, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
philbran
  • 242 Answers
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Posted on Dec 30, 2008
  • 132 Answers
SOURCE: top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 1244 Answers
SOURCE: loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Posted on Jan 18, 2010
  • 291 Answers
SOURCE: washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Posted on Feb 16, 2010
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts. http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
My top loader Kenmore type 111 is working fine until it get to the spin cycle. It won't spin and it makes a really loud buzzing sound. like a weedwacker or something. Help!!!
verify that hot and cold water are not reversed and BOTH are turned on. Sounds like water is shut off. Water valves are noisy without water pressure.
Sep 06, 2010 | Kenmore 22642 Top Load Washer
Washing machine making loud roaring sound during spin cycle
Feb 16, 2010 | Washing Machines
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
ROARING SOUND IN SPINN CYCLE
your bearings are shot your washer needs to be rebuilt it would be cheaper to go buy a new machine
Dec 23, 2008 | Maytag Legacy Top Load Washer
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Dec 11, 2008 | Washing Machines
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washing Machines Logo
    206 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
