Question about Samsung DMT400RHS Builtin Dishwasher
Over-water error on samsung dmt400rhs
Dishwasher fills and shortly after drains down and flashes error. If i hit power button it stops draining. I repeat this over and over. The cycle never starts.
I outlined my solution in another Fixya post here: http://www.fixya.com/support/t12931471-over_level_water_error
Posted on Apr 21, 2013
Daniel S
  • 4323 Answers
SOURCE: My DMR78AHS dishwasher stopped washing. It runs
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 24, 2011
  • 432 Answers
SOURCE: My new samsung dishwasher is not draining. What
Make sure the drain hose is not blocked.
Look at the hose from the connection on the dishwasher to the sink to be sure its not pinched or squeezed tight.
And,remove the hose from the sink drain connection and check that connection for a blockage in both directions.It my have a sink drain blockage.
Have a bucket and towels ready for a possible water mess.
Posted on Oct 29, 2009
SOURCE: My Samsung DMR77LHS dishwasher has lost power
Hi, whenever a fuse of that magnitude, or any fuse really, Blows, you should never just replace it, as to have any device, blow a fuse, trip a breaker, requires a major fault, they do NOT blow spontaneously ever. So you have had a major short circuit inside your machine, at some stage, usually this is in, the main Controller Board, most likely the bridge rectifier has gone short circuit, or a capacitor, But it could be anything even the motor?anything like this then will blow the fuse. The reason the fuse blow is to prevent a fire and explosion or both, as if an unlimited amount of current could be drawn, it would be catastrophic, so a fuse blows to disconnect the power. The Cause of this MUST be discovered before one ever attempts to replace the fuse. Luckily, it seems in this case the fault has blown an open circuit on the main Board, and this has prevented any further trouble.
Really after such an event as this one should engage the services of a professional, as anyone untrained may mis something that later on my even prove fatal. Get this unit looked at by a professional service person, ask for a 'Quote" if concerned about costings, then you can make an informed decision as to what to do.
Your support site is below,
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP06&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=DMR77LHS
Posted on Sep 14, 2010
mc1bean
  • 3053 Answers
SOURCE: Dishwasher is a SAMSUNG - The ERROR message was
Hello, tom
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
mc1bean
  • 3053 Answers
SOURCE: samsung dishwasher model dmr77 runs for 3 mins
Hello, kurt
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Samsung dmt400rhs blinking HEAVY light
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Jul 09, 2014 | Samsung DMT400RHS Builtin Dishwasher
Fills then drains
Sounds like the problem is the drain pump. There is probably something stuck in it. You will have to look properly and sometimes wire is hard to detect in the pump. If this isnt the problem it maybe be the solenoid. But check the pump as I find it is usually that.
Mar 16, 2014 | Samsung DMT400RHS Builtin Dishwasher
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
Jan 10, 2014 | Samsung DMT400RHS Builtin Dishwasher
Samsung Dishwasher can drain, but gives "drain error"
Sounds like it could be those same water level sensors you worked on before. Only now its telling the thing that there is water still standing in the unit. Try cleaning those sensors again and I know this sounds obvious but check all your conections.
Jan 08, 2013 | Samsung DMT400RHS Builtin Dishwasher
Samsung DMT400RHS Builtin Dishwasher Logo
909 people viewed this question
Top Samsung Dishwashers Experts
Rod
Rod
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
