Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag stacked washer/dryer Model LS7804
I have an older model Maytag washer/dryer 7804 and just recently have experienced the same problem as with the 7806 model. When I turn the selector switch to the minutes to wash, the water will not come into the tub nor will it agitate. However, I can move the selector switch to spin and it will spin out without any water in the tub. Nothing happens when I turn the selector switch to rinse.
  • 5 more comments
  • Muriel Akins Jul 24, 2007
    We ended having someone come and take a look at the washing machine. There is a fuse (1 AMP) that is tied to the selanoid (spell?) water valve. So far we have only replaced the fuse and the washer is working - for how long uncertain. The one thing that is puzzling is that the service rep and the schematics for this part on the internet all say a 1 amp fue, however, the fuse we took out was 15 amp.
  • HARRY808 Mar 15, 2008
    Thanks. How do I get at that fuse,because it seems I have the same problem.
    At first I thought about the solenoid itself or the switch,but it might be the fuse.
    Thanks for any help.
    I don't have a manual for the unit.
    Harry
  • Anonymous Mar 15, 2008
    my mom has a stacked maytag unit and the water wont fill but it will work on spin cycle only.I've read about a lid switch but don't know where it is or how to get at it help
  • Anonymous Jun 24, 2008
    I have the same problem. Took the fuse out and jury-rigged it so the washer would run. The fuse isn't marked so don't know what amp to replace it with.
  • JWSKOLAUT Dec 09, 2008
    hAVE A mAYTAG wASHER mODEL lse 7804, WILL NOT FILL WITH WATER, THEREFORE WILLNOT START. hAVE REOLACED WATER LEVEL SWITCH. STILL WILL NOT FILL WITH WATER?
  • jack_sinnett Mar 09, 2009
    I have teh same problem and it turned out to be a fuse. REmove the Front lower panel that is in front of the washer unit. There are two screws on the bottom to be removed. The panel just pulls out with some force. On the left handside half between up there is an inline fuse. On mine the rating is 4A 250 VAC.
  • Anonymous Mar 30, 2014
    Maytag model MAV7200AWW. The washer goes all the way thru its cycle till it comes to the spin cycle.it pumps out the water but does not spin dry.
Washer doesnt run through the cycle, the dial doesnt turn.
Posted on Jun 08, 2010
    Novelist:
  • 159 Answers
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Posted on Jul 12, 2007
I HAVE REPLACED WATER LEVEL SWITCH. NO IMPROVEMENT. wHAT DO i DO NEXT?
Posted on Dec 09, 2008
Need schematic for maytag washer model # ka606 for control panel/timer
Posted on Mar 21, 2010
SOURCE:
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
How to fix a Maytag LS 7804 leaking water into the tub
One of your water inlet valves are not closing all the way and needs to be replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Apr 27, 2014 | Maytag LSE7806A Top Load Stacked...
Where do I find the model #?
Typically on the stacked washer/dryer the model# will be on a label inside the dryer door
Sep 06, 2011 | Maytag LSE7806A Top Load Stacked...
What stacking kit do I use for my new Maytag 2000 series washer & dryer? It's model # MHWE200XW
Here is the link to Maytag.com's info on that stacking kit http://www.maytag.com/-[MAL2424AXX]-1100999/MAL2424AXX/
Aug 17, 2011 | Dryers
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
2,642 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
