Question about Moen Home
Shower knob keeps turning - Moen Home
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
Posted on Aug 22, 2009
When I turn the dial to put shower on the temperature dial is now moving with it so I don't know what temp it is! I have a triton power shower.
Thank you for supplying a picture. The two controls could be binding. Try holding the temperature setting with one hand while turning the shower on with the other. If this doesn't work, you may have to remove the knobs to find what is causing them to bind. The upper knob may be attached too tightly, causing it to bind on the lower knob.
Jan 26, 2015 | Home
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
System won't switch to shower
You need a diverter in your spout. The spout will screw off and the new one will screw on. Lift the ball while the water is running and it will divert the water to the shower.
Dec 14, 2012 | American Standard One Handle Tub & Shower...
Hansgrohe Croma 160 shower - how to adjust the holder for the hand shower
There should be a tensioning knob on the left side of the slider. You should be able to tighten this tension knob and keep the slider from slipping down the bar. If you need further help feel free to contact me Hansgrohe Tech at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Dec 12, 2012 | Hansgrohe Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
I have an american standard shower knobs for cold and hot with a center control that directs to shower. Tub faucet leaks. How do I fix this?
Pull the knob off...usually the screw is behind a cover in the center of the knob...
Behind the knob you will find a nut that is the packing nut ... this is what keeps the water from running out around the stem...turn that nut clockwise a quarter to a half turn or until snug...
this iwll fix your leak...
heatman101
Aug 14, 2010 | Plumbing
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Shower head dripping cant turn shower knob off
Aug 21, 2009 | Home
Leaking shower head
Check the spout pull knob . Debris can be keeping it from closing completely.
Jul 05, 2009 | Moen & One Handle Tub & Shower Faucet
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Home Logo
23 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
