Question about Linksys Wireless-G Broadband Router
Change password wireless-g 2.4 ghz
  • 826 Answers
First open the browser ->put the IP address(normally IP address of d-link router is 192.168.0.1 but you should check the manual ) ->login using username and password.
Go to the "Security" tab or option and click on WEP or WPA, select the encryption, choose a password and click save or apply.
If you need any kind of technical assistance you can contact for Router support
Posted on Jan 17, 2013
Where to find the password
http://arris.force.com/consumers/articles/General_FAQs/SBG6782-Admin-Login-Setup
if you have not changed the default password and user name !
it is listed on the web page on the above link
Go to wireless tab at top of screen and look up WPA Key or WEP key and make a note of what it is on 2.4 GHz frequencies as I think this will be dual band with 5 GHz as well but Ipad will run on 2.4 GHz only as it will be 802.11n as opposed to 802.11AC
Note if you changed the user name password or user name you will have to reset the router back to factory defaults but be aware everything defaults so ISP cable settings reset (would need ISP to tell you what they are and help set them back up)
(wireless settings change so you need ethernet cable directly into router to set up wireless)
Hopefully your still set up on the router on the default user name and password !
Jul 02, 2015 | Arris Surfboard Extreme Docsis 3.0...
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Apple products won't connect to network
May experience is that a lot of Apple products have problems with 5 Ghz wireless unless the conditions are near perfect. 5 Ghz has more difficulty penetrating things like walls than the older 2.4 Ghz. If during the setup you decided to disable the 2.4 Ghz, this could be the problem.
Apr 17, 2017 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I forgot my pass word and want to change it. My daughter put in her security pass word and can't remember it for a wireless-G 2.4 GHz Broadband rouuter.
Hello
You can do a factory reset.
1 unplug all cables to router.
2 Hold down small reset button behind router,use a pen tip to hold this button in for 30 seconds.
3 Reconnect cables,power cable first.
4 Log into router using default password and username.Which should be......
username=admin
password=password or admin
Once loged in you can reset your username and password to what you want.
Oct 13, 2011 | Linksys Wireless-G Broadband Router
My problem was,my wireless connection is unsecure,how do i secure my wireless connection?
1) Open your Internet Explorer program or any other web browser.
2) In the Address Box at the top of the browser window, type http://192.168.1.1 and then click on Go, or press the Enter key on the keyboard. A window should appear in the center of the screen asking for your User Name and Password.
3) Leave the User Name box blank. Type admin in the Password box, then click on OK, or press the Enter key on the keyboard.
Note: To change the password from admin to a more secure password:
1) Click on the Administration tab when the Linksys Wireless Router Setup page appears.
2) Type the password you want in the Password:box next to Local Router Access.
3) Click on Save Settings.
4) Be sure you remember or write down this password and the encryption password in step #13 below.
4) The Linksys Wireless Router Setup page should appear.
5) Click on the Wireless tab.
6) Because some of your neighbors may also have Linksys Wireless Routers and not know how to change the SSID (the SSID is the name of your wireless network.), change your SSID from the default name, which is linksys, to something unique, such as johnsnet or myhomenet.
Caution: Do not use spaces or weird characters, such as $ % ^ & * #, in the SSID.
7) Change the Wireless Channel to Channel 1 - 2.412 GHz. (The second part of the channel is the frequency: 2.412 Gigahertz.) You can also use 11 - 2.462 GHz. Most people use Channel 6 because this is the default Channel, so you don't want to select Channel 6; use Channel 1 or 11 instead.
Tip: Unfortunately, cordless [landline] phones, Bluetooth devices and microwave ovens may use the same frequencies as your wireless networking equipment. If you suspect that these appliances are interfering with your wireless network, try experimenting with different channels.
8) Click on Save Settings.
9) Click on Continue.
10) Click on Wireless Security.
11) Under Security Mode, click on the Down Arrow and then select WPA-Personal, unless you have an older wireless network card in your laptop which can't useWPA, in which case, click on this for instructions on setting the Security Mode to WEP.
12) Under Encryption:or WPA Algorithms:, set this to TKIP.
13) Under WPA Shared Key, type in your desired password, which should be at least 8 characters long, but not contain any spaces or weird characters, such as $ % ^ & * #.
14) Click on the Save Settings button to save the settings.
15) Click on the Continue button.
Sep 08, 2011 | Computers & Internet
How to use dual band on router?
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 02, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Adapter recognizes wifi but windows xp won't
it may need a Wireless Ethernet Password (WEP) key
Mar 16, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
Password and user name
Yes what would be your problem though?
Mar 05, 2009 | Motorola Canopy 5.2 GHz Wireless Access...
Linksys wireless-G 2.4 GHz broadband Router
What is the model No. of the router ?
You can open the setup page by typing 192.168.1.1 in the address bar of Internet Explorer / Firefox.
The default password for linksys routers is admin.
Once in the setup page, click on wireless and click wireless security. There you'll find the wireless security keys.
Hope that helps :)
For information on wireless security, click here.
For the updated list of firmwares, click here.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
