Question about 533 2way Security Remote Start System
Remote start python 533 attempts to start the car, shuts off, then on a again, does it 3 times, then stops
Frustrating. I had the Python 533 installed on my 2007 Honda Civic Hybrid and I've taken the vehicle back to the installer three times since install Dec. 2012. I lock the vehicle with the remote starter. When I press the start button, the vehicle will start (the count down timer will not appear), the vehicle will stop, start again, then stop three times. Then stays off. I don't want to take it back without having more information...help is appreciated.
  • 139 Answers
There are three possibilities for the situation you are describing especially if the vehicle has been cold for a while. The first possible cause occurs when the smart tach feature is used. In this case, the 533 is not receiving the proper signal from the vehicle that shows the engine is running. The remedy for this problem is to connect the tach wire from the 533 a proper tach source. The other two causes occur when the smart tach feature is not used and the tach wire is connected. If the tach wire is not connected to a good source for the tach signal in which case the wiring will need to be corrected. Otherwise, the tach signal will need to be relearned.
Posted on Jan 17, 2013
blueextc3221
  • 15935 Answers
SOURCE: i have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
  1. Lock + unlock at the same time - output 3
  2. * + AUX at the same time - output 4
  3. Lock + Aux at the same time - output 5
  4. Lock + * at the same time - output 6
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 01, 2009
sir fixalot
  • 146 Answers
SOURCE: My Python 1400XP remote start is killing my
Installation Guide: http://www.abt.com/images/products/BDP%20images/N562P_6-03.pdf
Owners Guide: http://www.directeddealers.com/manuals/og/python/G562P_07-05.pdf
Posted on Oct 18, 2009
Testimonial: "Been looking all over the internet for help with wiring for my remote start. Finally got the answers. Thank you so very much!!!"
  • 20 Answers
SOURCE: My Python will start the truck and it will run for
it sounds like the tach needs to be relearned.....if it's still connected. find your valet button, start the truck with the key, then push the valet button down for at least five seconds, the led should light up solid if the tach is learned, once the led lights up you can release the valet button and turn off the truck. it should remote start fine. hope that helps
Posted on Jul 08, 2010
logosc75
  • 625 Answers
SOURCE: I am attempting to install a Python 1401 in my
Make sure that the neutral safety wire (small black with white) sees a chassis ground. If you connected the toggle switch to the wire, confirm that the other side of that wire is connected to a good ground. Confirm that the hood pin switch wire (gray) is NOT seeing ground during remote start. All of the above are relevant for a vehicle with an automatic transmission. If the clicking sound that you hear is also flashing the parking lights, that is a remote starter error message. Six flashes concern the hood shutdown (-) or the brake shutdown(+). Seven flashes concern the neutral safety shutdown.
Posted on Jan 23, 2011
slick42371
  • 42 Answers
SOURCE: Python 1600 XP Remote Starter my
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
Posted on Feb 02, 2011
Remote start/alarm works not working properly
First, find the fuse, and sensor to the devise. Pull the fuse and waite a few minutes then replace. Do the same with the sensor, this will clear the devise settings on the cars computer. Then start your car and let it run through the computer system check of all car devises, it will locate the Python devise and resetit. If you have trouble in this process, look your unit up on line and call the tech department and they will walk you through the process. Then go back to Jeffy Lube and have them comp you for their lack of knowing how to work "around" this devise.
Apr 29, 2017 | 533 2way Security Remote Start System
Remot start/alarm system not working properly
Sounds like something out of sync reboot. Disconnect batteries and reboot.
Jan 15, 2014 | 533 2way Security Remote Start System
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
I recently installed a python 872 on my 2002 maxima. Now everytime i use the remote start and open the trunk the car shuts off and restarts in about 10 seconds. I had other dei alarms and never had that...
It's possible that the installer has the engine monitoring option programmed for voltage and, the unit sees a drop in voltage when operating the trunk...causing the remote starter to shut down. If so, try programming the unit for tachless instead or, hook up the tach wire.
Jun 10, 2011 | 872 Responder LE Security Remote Start
My Python will start the truck and it will run for around 20-3- seconds then shut down. Then start back up then shut back down. It does this three or so time and then stops. What can I do? I have a 2000...
Jun 27, 2010 | 702 447 Generation 2 Ask LED 2Way Security...
When I start my car using my 950 Python auto start remote, the car runs for only about a minute then turns off. How can I fix this?
Does your vehicle surge at all when its running becuase if the Python see's any fluctuation in RPM it will kick out.
Dec 09, 2009 | Install Essentials 489P Responder 2-way...
I have a python sst car alarm
Hope this helps.
Mar 01, 2009 | Python Vehicle Parts & Accessories
533 2way Security  Remote Start System Logo
325 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
AzVip
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
