SOURCE: Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
SOURCE: GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
SOURCE: oven won't light, even with ignitor getting red
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes
Other reasons that your oven may not bake are:
SOURCE: kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
