Question about Miele Washing Machines
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
  • Miele Master
  • 17,129 Answers
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Posted on Jan 17, 2013
4 Suggested Answers
  • 70 Answers
SOURCE: Miele W1203 washer drain and intake lights flashed
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work. If Fault reoccurs then you have a leak.
Posted on Jun 02, 2010
SOURCE: W1203
Front lower left corner has an access door.  Pry the access door open.  Inside you will find a yellow tab that will open the machine glass bubble door. Below the yellow tab is a cca. 2.5 inch screw-in plug.  Place a pan in front of the machine and unscrew to plug.  Water will drain out of the machine.  With the plug removed, tilt the machine forward past 45 degrees until all water has drained out.  This will reset the washer.  Insert the screw-in plug.
Posted on Jan 28, 2009
reverendrave
  • 24 Answers
SOURCE: My Miele Touchtronic W1119 shows the error message
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Posted on Sep 15, 2009
Miele w1203 washing machine at end of cycle fault lights intake & Drain and the ---on panel lighted Buzzing & will not operate now. I have cleaned drain at bottom left
There are two impellers, one of which may be stuck. It's easy to wiggle them with some tool to free them up. Search on YouTube for videos on where to find them (both are right in the bottom under the filter screen so easy to get to).
Jul 11, 2017 | Miele Dishwashers
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
Intake and drain error indicator light came on and machine will not work at all
Intake and drain error light is on and water backed up onto the floor but not in the back of washer it was dry what is wrong?
Jan 31, 2011 | Miele Touchtronic W1113 Washing Machine
Miele W1203 washer drain and intake lights flashed together and now will not change modes. Can I reset it so that it will work again?
May 17, 2010 | Miele W1203
Drain intake indicator flashing. We have cleaned all but the intake filter. How do you clean or check to see if cleaning is necessary of the intake filter?
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
Sep 25, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
W1203
Apr 14, 2008 | Miele 11120301 W1203 Touchtronic Washer...
Washing Machines Logo
979 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
