The frontloader door is jammed - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
Click on this lick for tips: Door lock
Posted on Jan 17, 2013
My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
May 08, 2012 | Frigidaire Washing Machines
Hi..am using frontload lg washer since past 2yrs...the door seems to get jammed..am able to open the door only if i try harder..reason?
replace the door lock assembly and this would solve your door issue as these age the inner clip on the door assembly starts to deteriorate with use of opening and closeing the door it is mainly made up of small plastic pieces if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future thanks Rick
Apr 22, 2011 | LG WM-2277HW Front Load Washer
How do I open/unlock part way through a drying cycle?
you would hold down cancel or stop for 5 seconds usually the cancel option puts the unit into drain in which after it finishes draining it would unlock the door on the other hand if you had a door switch error and your unit was a frontload washer and you are unable to get into the unit even after the unit has stopped you would remove the lower panel on the machine and reach up along the side that has the door lock there would be a small cord with a round circle on the end by pulling this cord down this also unlocks the door this 2nd par is only for a frontload washer if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks
Rick
Mar 23, 2011 | Washing Machines
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
