Question about Health & Beauty
Resetting the scale
Can this scale HDM759 be reset to 0 for a beginning weight? It already has weights in its memory and I want to start from my beginning weight to track accurately. It says removing the batteries will not interrupt the weights recorded. How do I begin at 0?
Model is a Health O Meter bathroom scale #HDM759.
Thank you :)
  • 1 more comment
  • Anonymous Apr 10, 2009
    I'm looking to reset the users in the scale. I cohort of mine put all the same data in all 10 profiles and I can't figure out how to get back to a clean slate. How does one reset the scale or wipe a user profile? Anyone?
  • Anonymous Mar 21, 2014
    i get an "e" every time i step on the scale, after i wait for the 0.0 and i changed the batteries already
  • Anonymous Mar 29, 2014
    Not weighing accurately.
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Posted on Mar 25, 2009
Need to reset the weight on the conair th300m. already replaced the battery
Actual weight is detected by a pressure transducer which may have failed. The constantly changing readout indicates there may be a problem with the internal circuitry.
Jun 16, 2014 | Weight Watchers Glass Electronic Scale
Resetting the scale to 0
mcdevito75 here, There should be some sort of knob or screw near the weight indicator too reset the indicator to zero. Make this adjustment without any weight on the scale.
Jun 23, 2010 | Terraillon TFA Nautic Body Fat Scale
How do you zero out a health o meter weight tracking scale?
After stepping on the scale to Activate your number (1-4), hold it down and it will say "reset" or (something to that effect), then Yes, or tap it once and it will say "no". If you want to reset, when it says "Yes", continue to hold it down, and it will then reset to zero.
Jan 25, 2010 | Health-O-Meter Health O Meter Weight...
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Can I reset the scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Dec 31, 2008 | Conair WW60 Weightwatchers Scale
I cannot set another user or reset current user
Dec 22, 2008 | Conair WW61, Weight Watcher Memory...
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Aug 24, 2008 | Health & Beauty
Health & Beauty Logo
3,362 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
