Question about Canon PowerShot A710 IS Digital Camera
Card locked error
Need help fixing card locked error
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 17, 2013
Tip
There is another Solution to get out sim card error / Invalid sim card from...
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Dec 09, 2010 | Cell Phones
My camera Canon sd 940 shows an error memory card error and card lock, how to fix it?
Have you tried unlocking the card with the small slider switch on the side of the card
Feb 15, 2015 | Canon Cameras
Lexar sd card error, it is a 16gb Lexar sd card. When I put the card in my camera it says "card error-card is locked. Need to know how to fix this card.
Apr 21, 2014 | Lexar Electronics - Others
Hello, I'm getting the message "Memory Card Error
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Dec 02, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
MEMORY CARD ERROR, CARD LOCKED BUT IT ISN'T LOCKED HOW CAN I FIX IT
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Apr 02, 2010 | Canon PowerShot A530 Digital Camera
Memory card error E50
Hello
Kind regards
Andrea
Apr 28, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Card error
the problem could be multiple things:
1. it's switched into card mode... without a cord 2. the card is locked, this can be fixed by retrieving the card from the camera, then pushing the lock switch down away from the word "lock" (the opposite direction of the tiny little arrow) 3. THe card is corrupted, for this there really is no fix, sorry.
hope this helped- snowsurfer58
Sep 19, 2008 | Canon ZR300 Mini DV Digital Camcorder
Canon PowerShot A710 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
