Question about Welding Tools
I have a pro-mig 135 and while welding the arc surges up and down along with the wire feed.the feed is real jumpy and will not keep a constant smooth puddle
  • 169 Answers
You need to clean and perhaps replace the liner in your wire feed gun. The liner gets tiny bits of dirt and **** up inside. After even normal use for a while, the liner itself gets worn away and makes the wire stick rather than smoothly poke into the puddle.
Liner maintenance time is also a good time to check the feed wheels for wear, look for the little ruts in the wheel to be dull or obviously worn at the edges. Wipe off the drive shafts and housing as long as you've got the drive wheels off anyway. :-)
All of this should have a nicely illustrated procedure in your user manual.
The other thing that can cause problems is that the welding wire can sometimes get rusty enough to be sticky inside the liner. Roll off a good length of wire (2 or 3 wraps around the spool) and inspect it for any sort of funkyness. If in doubt, blow out the liner, change the wire, and weld something to see if it works better.
Regards,
Carl
Posted on Jan 26, 2009
Settings to weld 2.5mm mild steel with rossi 130amp mig welder
set the volts to around 20 and then adjust the wire speed to obtain a good arc
wire feed speed also adjusts the volts but you have to in the area as the feed is like a fine tune
adjust the volts up or down to get a good weld
practice on scrap to get it right
Nov 19, 2017 | Welding Tools
A snap on mm250sl that i cant control the wire speed feed, from 4-10 on the dial it runs full speed, from 4 down it does nothing. ive had this welder for 20 plus yrs with no problems till now
The wire speed knob does more than control the wire speed. As the wire speed is increased the welding power must also increase and the circuitry to do this and keep things in sync is fairly complex. The fault is probably within that circuitry and the repair will require no small amount of skill and test equipment or a replacement circuit board.
Complex electronics can be fairly sensitive to high temperatures and voltage spikes and surges and apart from the natural sort that arrive along the mains electricity supply mig welding is an electrically noisy process that can be quite stressful on those electronics. 20 years of trouble-free operation is quite a good record...
Oct 28, 2016 | Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
Hobart handler 135 wire feeds for about a two feet then stops feed motor runs well under no load
This happens to me all the time. Wear and tear has taken its toll and everything has to be maintained for it to work. Most likely the welding tip is worn and should be replaced. Lincoln electric tips work well and I will replace mine several times during the day. Also check your tension and make sure the wire will uncoil freely from the spool. You can remove the tip and make sure the wire will feed without it. If not, your liner may be worn out. Also a welding Jell will help keep the tip from cloging. It will still happen, but hopefully not on your first weld of the day.
Jan 15, 2011 | Hobart Handler 140 Mig Welder
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
Weld arc not stable. Wire feeds, good ground, everything looks good, liner pulled and cleaned, new tip.
Try moving the tip closer to your work and try turning your wire speed down
Most people want to crank up the wire speed when it spits and sputters
Turn it down
See if this helps
Mar 16, 2010 | Hobart Handler 140 Mig Welder
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
348 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
