Question about RCA L32HD32D Refurbished Widescreen 32-Inch LCD/DVD Television Combo, Display Aspect Ratio 16:9, Display Resolution 1366 x 768, Brightness 450 cd/m2, Panel Contrast Ratio 1500:1, Viewing Angle Horizontal/Vertical 176/176, Response Time Gray to Gray 8ms,
How 2 switch from analog 2 digital - RCA L32HD32D Refurbished Widescreen 32-Inch LCD/DVD Television Combo, Display Aspect Ratio 16:9, Display Resolution 1366 x 768, Brightness 450 cd/m2, Panel Contrast Ratio 1500:1, Viewing Angle Horizontal/Vertical 176/176, Response Time Gray to Gray 8ms,
What's the difference between digital switches and analog switches?
Basically, the exchange of digital and analog Huawei switch mode, there is a difference between digital switch USES time-division switching, analog switch is the interchange of air separation.That is to say, the way of digital switches is non-blocking switching, analog switches have rope limit of the road.
Nov 03, 2015 | Electrical Supplies
How do I switch from anaLog to digital as Samsung TV now showing week or no signal but has been working ok for some years on digital now seem to have switched to analog
Most Samsung tv's change from analog to digital (and vice versa) by entering the same channel number you're watching at the moment, again. If that doesn't help, check the manual for detailed information.
Feb 28, 2015 | Samsung Televison & Video
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Switching from analog to digital on scepter x50 hdtv
All the new flat screen TV's work on a digital signal only. There is no switching from analog to digital anymore. The signal from an antenna is digital now too. There are no analog signals anymore.
Sep 07, 2013 | Sceptre Televison & Video
My Sony AV unit (probably 3 yrs old) suddenly switches from all 5 channels to just the two front without warning; I can push enough buttons to return it to all 5, but sometimes it switches back and forth...
You don't name the model but if there's asettign for audtomatically selecting digital vs analog when both are attached it's losing the digital signal and automatically switching to the analog feed. Find it in the manual. lacking a setting, it prefers digital over analog and will switch to analog on digital signal loss.
Analyze what source(s) are involved and investigate WHY you're losing the bitstream. Optical cables must be run with smooth loose bends so the light strength is not compromised.
Feb 04, 2011 | Sony A/V Receiver
Analog is cutting in and out while channel isn't being changed. Also, channels in analog have no sound at all. I tried to switch signal select to auto and the problem continues. what should I try next?
If you're only using analog audio, switch the signal selection to manual or analog.
If the source(s) that do this are primarily digital and they experience any problems the unit will want to dynamically switch to its analog path. If there's no analog path connected from the same device(s) you'll get silence every time it switches to analog. Observe the display when the problem occurs.
May 30, 2010 | Pioneer VSX-90TXV Receiver
My JVC tv Is in digital and i want it in Analog
Look to see if your remote has a button with A/D on it. That is the button to press to switch back and forth between the analog and digital tuners.
Mar 28, 2008 | JVC HD-56G886 56" Rear Projection HDTV
No signal analog
Press the front screen button that has an arrow. It will be switching from analog to digital and digital to analog if you press it again.
Mar 12, 2008 | ViewSonic VX2235WM Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
RCA L32HD32D Refurbished Widescreen 32-Inch LCD/DVD Television Combo, Display Aspect Ratio 16:9, Display Resolution 1366 x 768, Brightness 450 cd/m2, Panel Contrast Ratio 1500:1, Viewing Angle Horizontal/Vertical 176/176, Response Time Gray to Gray 8ms,  Logo
13 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
