Question about GE Wireless Optical Mini Mouse 3087897985
Where is the link button?
All of a sudden my mouse doesn't work. It is plugged to my desktop. The receiver works.
the mouse started to blink, the instruction manual is very very basic. They say "press the link button at the bottom". Where is it???? There is a picture of the front but not of the back (not of he receiver either). I see at least 2 buttons, I pressed them and it does nothing. I changed the batteries, it is worse, no blinking at all.
Anyone could help, please? Thank you very much
  • 9 more comments
  • ijlem Jan 24, 2009
    PS. Sorry, I thought there was more info displayed since I went to the specific topic.... It is a GE Wireless HO97985. I think it is not relevant, but I use Win XP SP3.
    Thank you
    Doesn't work at all :(((
    I put other new rechargeable batteries, pushed the button on the transitter and the mouse, no moer light, either blinking or not. I mean there is the light at the bottom (optical?), but not on the top. I am sure I installed them correctly, it is not that difficult.
    Thanks for your help, cpenzes
    "is the USB plugged in secure", not sure I understand that. I don't think there was any software, it was just a little plastic, I pushed the buttons several times, and true, it is not visible, hence my first question.
    I have already tried 2 new sets of batteries, one normal, the other rechargeable, It is a USB hub (4 pluggs), but it was working this morning!!!
    I plugged an old one (Logitech), and it works, So I could check device manager in THAT computer (I am working on another one). Hmmm... I have now 2 mice (2 x HID compliant mouse)
    Would you suggest I update any driver?
    Thanks
    Each mouse appears as Microsoft :((( None is.
    no cd
    it is right clicking that gives me Microsoft
    ah, ok... the mouse is GE wireless optical HO97985
    Why do I get Microsoft (for both)? (of course in device manager -> mice and other pointing devices -> properties
  • ijlem Jan 25, 2009
    That's very nice of you, you try hard to help. It is my first post, I didn't know the site, but it might not be the last one :). you mean I have to restart the computer?
    You can send it to ijlem@vfemail.net
    Thank you so much
  • Anonymous Jan 25, 2009
    I have a problem sending you an email, it doesn't work, the security istoo high, I have to do it from the server, it happens sometimes
    Please bear with me, I know it is always easier when... you have the computer AND you know :)
    ok, can we do it now?
    how do you want to proceed?
  • ijlem Jan 28, 2009
    Thank you so much, you tried very hard to help me, I don't have any idea why it doesn't work (you either), maybe I will find the solution some day.
    Thanks again
    Genius:
  • GE Master
  • 1,102 Answers
Make sure the batteries are in correct
PUSH LINK ON TRANSMITTER
then on the bottom of the mouse there will be a button IF NOT on the USB THERE IS A BUTTON PUSH THAT
if mouse still does'nt work restart then again follow instructions above
Let me know if that was helpful
Posted on Jan 24, 2009
  • 9 more comments
  • DEKR
    DEKR Jan 24, 2009
    there may be a USB button to push for reset of mouse and is the USB plugged in secure.
    If you got any software with the mouse i would run it again.
    Do you have regular batteries to try and are you sure there is no button on bottom of mouse to push
    on the bottom of my mouse you can barely see the reset button
    don't forget to check for reset on USB plug in you can even try a different USB port if you have a second one
    Next time you need to change the batteries shut down
    If you've done everything i don't what is wrong
    check device manager see if mouse driver is showing
  • DEKR
    DEKR Jan 24, 2009
    okay
    your going to need to update ge driver in device manager
    right click and update
    what other mouse is showing
    your pobably having a conflict
  • DEKR
    DEKR Jan 24, 2009
    if you right click the driver then properties should give you more info
    do you have your software cd
  • DEKR
    DEKR Jan 24, 2009
    when you right click the driver you should get an option for properties
    what is your mouse type again I am going to look and see what the proper driver is
    you can try and update your first driver then restart and plug the ge mouse back in
    during restart
    i just think you may have lost the driver
  • DEKR
    DEKR Jan 24, 2009
    if you updated first one and mouse still does not work then uninstall first one
    then update second one again restart unplu logitech and plug ge in during restart and reset if that did't get it going then logitech back in
    let you know what your driver should be in a minute and then we can fix it
    mean time i'll find proper driver
  • DEKR
    DEKR Jan 25, 2009
    I have your mouse driver but i would have to send it via e-mail
    then you can download it
  • DEKR
    DEKR Jan 25, 2009
    FOLLOW THE STEPS ABOVE THAT I HAVE INSTRUCTED
    yes update and restart and plug ge mouse in press rest buttons
    and see if that solved it
    I DO MY BEST TO HELP BUT SOMETIMES ITS HARD WHEN YOU DON'T HAVE THE PC IN FRONT OF YOU
    please check to make sure your reciever/transmitter is also securely attached
    in the meantime I will send the driver with proper instructions
  • DEKR
    DEKR Jan 25, 2009
    my driver is to big to send to your mail so i will manually install it with you
  • DEKR
    DEKR Jan 25, 2009
    okay whenevr you are ready i will guide you through
    just let me know it's not hard and the mouse was working before so it should work again
  • DEKR
    DEKR Jan 25, 2009
    I am going to send you step by instructions via e-mail
    your mouse should still be showing since you never uninstalled it
    I just think you were having a conflict with driver cause you had two drivers in device
    before i do this uninstall any mouse drivers then remove the mouse you are using
    from the tower of your pc then attach the mouse you are trying to repair
    then restart system
    This may automatically detect your mouse
    but you must first uninstall any mouse drivers from device
  • DEKR
    DEKR Jan 28, 2009
    hey i have something to try i'll go on msn
3 Suggested Answers
rickyostrom
  • 274 Answers
SOURCE: GE wireless mouse not linking
Did you press the reset button under the mouse?
Posted on Nov 25, 2008
  • 96 Answers
SOURCE: The mouse is working fine, but for some reason the
try connecting the usb receiver to a different port might loose or not working properly..
thanks
Posted on Aug 11, 2010
How to install
Plug in the reciever into the computer and make sure the mouse has fresh batteries. Once you are in Windows, press the link button on the receiver. The indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
Jan 18, 2011 | GE 97985 Mouse
I have a GE wireless optical mouse that has decided no to work
I had the same problem till I discovered there are two buttons (not just one) you have to push to re-link the mouse and the USB receiver. Plug the little receiver in, push the tiny "connect" circle on the receiver (which is actually a button I guess), then wait for the red light to start blinking. Then press the little link button on the bottom of the mouse.
Jan 18, 2010 | GE Wireless Optical Mini Mouse 3087897985
I worked for a while now it doesn't
I had the same problem till I discovered there are two buttons (not just one) you have to push to re-link the mouse and the USB receiver. Plug the little receiver in, push the tiny "connect" circle on the receiver, then wait for the red light to start blinking. Then press the little connect button on the bottom of the mouse.
Nov 27, 2009 | GE Wireless Optical Mini Mouse 3087897985
Where is the link button on the actual mouse device? The USB is being recognized, but the mouse isn't working.
There are two buttons (not just one) you have to push to re-link the mouse and the USB receiver. Plug the little receiver in, push the tiny "connect" circle on the receiver, then wait for the red light to start blinking. Then press the little link button on the bottom of the mouse.
Oct 14, 2009 | GE Wireless Optical Mini Mouse 3087897985
Cordless Desktop EX110 Mouse isnt working
Computers wont recognise user errors. Just kidding. i had the same issue with mine. After some period of time it will begin to do what i call Freeze Response. Where the computer recognizes it's function is there, but the mouse is considerably frozen. this works for me. If you still have the Cd than unplug your mouse and reinstall it. if you reinstall it with the mouse in, it just fixes software errors.
Or
Turn your pc off, unplug your mouse. Take out the batteries. boot up your pc, wait till everything loads up into windows or MAC, plug in your mouse, put the batteries back in. And wait for it to automatically connect. if it does not hold the connect on mouse and press connect on receiver. You should be on your way hopefully.
Feb 14, 2009 | Logitech Cordless Desktop EX110
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Logitech ex110 keyboard stopped working all of a sudden. unable to connect. the mouse still works fine. checked the batteries, they are ok. I have a Cordless Desktop LX 300 mouse and keyboard set. My...
If you know the batteries are good, then turn the keyboard over and find the small reset/connect button and press it. This resets /connects the board to the receiver. If it still doesn work, press the button on the receiver and then the mouse. Hope this is of help to you. Bud
Aug 11, 2008 | Logitech Inc Cordless Desktop LX 300...
GE Wireless Mini Mouse 97985
Press the link button on the receiver the indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
Jan 31, 2008 | GE 97985 Mouse
Keyboard and mouse
Nov 29, 2007 | Logitech Cordless Desktop EX110
Wireless mouse is not working
ya..there is a small button on back side of the receiver..plug the receiver to the USB port and press the button for few secs and red light will start blinking..then a similar button is there for the mouse below it..press it and it will work fine.
Sep 26, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
182 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
