Question about Uniden BC355N bc355n bc355n mobile/base scanner
Cannot program the scanner
We cannot figure out how to program it.
How do I program Uniden Bearcat 125AT scanner
Here is manual
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/BC125ATom.pdf
Sep 25, 2014 | Radio Communications
Motorola LI4278 Scanner 3of9 prefix ~ tilda
there's a program called 123scan2 where you can configure a prefix and outputs a program barcode
Feb 18, 2014 | Zebra LI4278 Barcode Scanner
Cannot get scanner programed
Most radio scanners these days have software that you can program from your PC etc, You will also need a cable, if not supplied. Check at the Uniden website. However you should be able to program it manually. Again the instructions that came with it? should tell you how.
Normally a scanner can be programed to scan between two frequencies ie 144 to 146 for the 2mtr amateur band etc
or you can program channels.
Feb 09, 2014 | Uniden BC340CRS Base Scanner
I can't figure out how to program my Radio Shack Pro-97 scanner!
If you can't program the unit using the instructions in the owner's manual, there's no way anyone can post a workable answer for you here. I suggest that you join a Yahoo users' group for the PRO-97. That way you can pose a problem to a group of users, plus get one-on-one assistance in programming your scanner.
Bill B.
Listening in since the 6y0's.
Oct 10, 2010 | Radio Shack Pro-97 Handheld Scanner
How can i get the instuctions to work my scanner on my canon mx300 ? i need to set my labtop up to my canon mx300 i figure out the printing but cant figure out the scanning set up .
First the drivers need to be installed, then the program you use to scan may need to be told that's the scanner to use.
Your program should then work fine
Usually you get a CD with it that does all that and supplies program for all functions.
Apr 19, 2010 | Canon PIXMA MX300 All-in-One Printer
Having major issues with programming my bearcat bc60xlt-1
You'll need to program the radio frequencies into your scanner before it will scan . For a list of frequencies in Anoka County CLICK HERE .
For specific programing instructions for your UNIDEN refer to your owner's manual. They will give you a step by step instruction on how to program the frequencies into your scanner memory (If you need a manual, CLICK HERE
...be sure to select the scanner option on their pull-down menu.
THEN when you have the radio frequencies stored into your scanner, you'll be able to press scan and away you go.
Be sure to adjust the squelch just high enough to eliminate the static...turn the squelch counterclockwise until you hear loud static, then turn Clockwise just enough to silence static...
Let us know if you still have trouble.
Jul 20, 2009 | Uniden BC60XLT-1 Handheld Scanner
I bought the scanner usb cable and cant figure out how to get new codes to program my scanner.
You will also need a software package to program your scanner. Unfortunately the cable does not come with the software. Try going to www.starrsoft.com and download a program called Win97. It is free for 30 days and makes programming a breeze and it can also interface with radioreference.com (if you are a paying subscriber to the radioreference.com site) to download automatically.If you don't mind doing a little typing, you can view the info on the site for free and enter it into the program.
Apr 26, 2009 | Radio Shack Pro-97 Handheld Scanner
I need a driver for an acer 6678-owe flatbed scanner for windows vista
I searched pretty hard and couldn't find any Vista drivers. I assume that scanner is relatively old. You can try this, but I don't know if your scanner has software:
Go to Start, then Control Panel, Programs, and under Program Features you'll see something that says "Use an older program with this version of Windows." Try messing with that and see if you can figure anything out. But I'm pretty sure there are no Vista drivers for that scanner.
May 24, 2008 | Computers & Internet
Programing
Here is a pdf format copy of the BC278CLT manual
http://www.uniden.com/pdf/BC278CLTom.pdf
Page 12 to program scanner frequencies.
Rollin CBs
Dean
Sep 30, 2007 | Uniden BC278CLT Base Scanner
Uniden BC355N bc355n bc355n mobile/base scanner Logo
69 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
