Question about Maytag Washing Machines
TRANSMISION PROBLEMS NO TURN GOOD AND FORS THE MOTOR
  • Maytag Master
  • 17,130 Answers
Possible this is due to friction on the drive mechanism. Start with a free motion test with your hand after disconnecting the mains power. If there is friction then you need to remove the shaft and drive and agitator.
Click this link for tips: replacing agitator
Posted on Jan 17, 2013
Transmission hard to turn motor overheated
Either the transmision is worn or stuck out or the motor is.
Disconnect the belt from the transmission and try turning the motor, then the transmission. If it is the transmission check to make sure a small sock or something else isnt jammed in the drum under the agitator.
Jul 01, 2011 | Speed Queen Washing Machines
All trans to engine bolts are removed. engine mounts are free, engine still won't come out. I don't know what else could possibly be keeping it from seperating. Is it absolutely necessary to remove...
YES YOU MUST SEPERATE TO GET TO FLYWHEEL
THER IS TWO DOWEL PIN ONE PER SIDE TOWADS THE TOP OF THE TRANSMISION
PART OF ENGINE BLOCK THEY OFTEN BIT AND HOLD ON GOOD IF YOU ARE SURE THAT
ALL THE BOLTS OF THE TRANSMISION ARE UNDONE YOU SHOULD PUT THE ENGINE MOUNT BOLT BACK IN PUT JACK UNDER FRONT OF ENGINE HARMONIQUE PULLEY TO
STABILIZED MOTOR THEN WITH SECOND JACK AT REAR OF TRANSMISION JACK UP TO
START THE RELEASE THEN LOWER BACK DOWN TO RELASE TOP OF TRANSMISION
THEN WITH SUTIBLE PRY BAR BETWEEN ENGINE AND TRANS PRY APART UNTIL FREE
FIRST I WOULD UNBOLT TORQUE AND PUSH BACK IN TRANSMISION AND PUT A RETAINER TO PREVENT TORQUE FROM FALLING OUT OTHERWISE YOU WILL NEED TO CHANGE THE TORQUE PUMP INPUT SEAL IT WILL LEAK IF SEPERATED
May 26, 2011 | Ford Expedition Cars & Trucks
Having problems with transmision. What is the cheapest way to fix. Buy another motor, or just transmision?
Best is to take an estimate from the Experts before you think of a full change.
Might be a an overhauling with the corrrect spares - original- will be the best option than a full change.
So take an estimate and decide.
Sep 06, 2010 | 1999 Honda GL 1500 SE Gold Wing
Wont turn over lights good battery good everything comes on but wont turn over dead
Try this. Take a small peace of wire and connect to the battery + lead. The other to the starter solenoid small screw looks like the one on the right in this picture and has a smaller wire. check this web site.
http://www.specialtauto.com/delorean-parts/images/starter-solenoid.jpg
If it turns the motor starter is good. Could be Neutral Safety Switch which may be in the transmision bummer. http://www.1aauto.com/1A/NeutralSafetySwitch
Oct 10, 2009 | 1992 Oldsmobile Cutlass Supreme
I have a 82 chevy caprice when I'm driving it will stop goin forward but the engine is still going strong
Check transmision oil level, Place car in park, hand break, open motor compartment and check transmision oil level with motor on idle. Good level?: transmision is bad, repare or replace the whole unit. bad level: complete and check for leakeges.
Jul 03, 2009 | 1991 Chevrolet Caprice
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Transmission
your torque convertor went out that is the clunking noise you hear . have this replace and this will solve the problem.. please rate this
Oct 09, 2008 | 2002 Oldsmobile Intrigue
Neptune MAH3000AWW Problems
It is most lickely a foreign object stuck in the tub.
Jul 18, 2008 | Maytag Washing Machines
Will Not Spin
bypass lid switch 2 wires go to it splice them and use wire cap if it starts spinning then use it till u can buy new lid switch good luck
Dec 14, 2006 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
