My bayantel telephone has no dial tone - Computers & Internet
Mix-it-up
  • 832 Answers
SOURCE: No Dial tone for fax
Did you choose the right input for fax? Or did you connect to the phone line in at the mfc? Did you choose the right settings? See handbook for that.
Posted on Sep 10, 2007
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
alexgalapin
  • 148 Answers
SOURCE: can't enter outgoing phone number....I have a dial tone
  • your phone or phone company may have used or set restriction on making outgoing calls
Posted on May 03, 2009
FixinFax
  • 3085 Answers
SOURCE: There is a fax tone when dialling our telephone number.
Set your fax to MANUAL MODE. You will have to press START when you know you are getting a fax.
This is the only way it will work without a dedicated fax line.
Posted on Nov 30, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: When telephone line is connected no dial tone,any
are you using a modem? do you have a fax machine? switch the fax off. if a modem is present the main phone must be connected to that modem and the additional phones place through out the house (using other phone jacks)
Posted on Jul 27, 2010
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
I replaced my desk phone with a wireless and I lost dialtone on all the phones
Are you saying you have a wireless desk cell telephone? Or is this a regular land line telephone with a wireless hand piece? If it is a cell phone with no dial tone, you must see your service provider - this is HIGHLY unusual. If this is a land line telephone with a wireless hand piece - be aware that the dial tone cones from your base transmitter, where ever it is located, (Normally this base should be withing 300 feet of the hand piece) and that base unit MUST be plugged into an active telephone outlet. In the USA, the standard jack is an RJ 11. I suggest you take your old telephone and plug into the outlet where your new base unit is located. Do you get a dial tone? (proves the line is good) Check all wiring - same type of contacts (for your country)? Still no dial tone? Take it back to the store and get them to demonstrate its operation for you - does it work at their store? ... if not, get a new telephone or an adjustment.
Jun 04, 2011 | Cell Phones
I have two dell laptops that are having the same problem of no dial tone
First of all, be sure that the connection you have configured on the computers are Dial Up connections.
If you have restrictions activated on the telephone line, removing them might help. Some other services of your telephone provider can also prevent your modems to properly detect the dial tone. It might be worth to take a look in that direction.
It might also be a problem with the telephone line. Try also to dial the number normally entered in the dial-up connections. You should hear a ringing tone shortly followed by noises similar to a fax machine. If you hear this, you access correctly to your providers dial up server and the problem would be with the two computers.
Apr 28, 2011 | Dell Computers & Internet
Dial tone of my phone disappears whenever i switch on my computer and my d link dial up modem can't find dial tone. What should i do?
Disconnect the telephone-cable from the computer's modem.
Does your telephone regain the dial-tone?
If so, then replace the computer's modem -- it is going "off-hook" as soon as you turn on the computer, not just when you try to use the modem to open a dial-up session.
Sep 27, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Modem tells me there is no dial tone
Connect the modem to a telephone-jack.
Make sure that the telephone-wire has *FOUR* strands, not just *TWO* strands.
Or, unplug the FAX, and plug a telephone into that telephone-jack, and listen for a dial-tone.
Do you have electronic voice-mail from your telephone company?
If so, does it "beep" a few times when you pickup the handset?
Such "beeps" can confuse any modem that expects *instantly*
to "hear" a dial-tone.
Nov 01, 2009 | Zoom ADSL USB Modem
HP OfficeJet 4215 can not send fax
Check for dial tone at the fax machine
Plug in a telephone on the cable from the wall.
Yes,
Something is wrong with the fax machine.
No,
Call the phone company or a telephone repairman.
May 27, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I have a Brother MFC 7220 - it won't print but says manual feed. Also the telephone is not working. All this was fine yesterday. The machine is about 1 year old.
Hi zoltansz
Have you tried the following
Use the telephone cord going in to machine on a regular telephone. If this works cord is fine. Plug cord back in to machine. Press the dial button on machine if you hear a dial tone check the settings for Pulse / Tone dialing (refer to manaul). If you don't here any dial tone the fax modem on the machine is faulty (posible lightning strike on telephone line. You will then have to take the machine in to a service centre.
Please feel free to uase the Repair Service Directory on this site to locate a service centre close to you.
Regards
Go-Tech
Dec 15, 2008 | Office Equipment & Supplies
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
