Question about Black & Decker 15.6 Volt DustBuster Vacuum
Vacuum sounds like it is working but there is no suction.
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Suction stops when vacuuming with the DC40 model
There may be a clog where the air flows from the brush roll into the vacuum
Jan 29, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Decreased suction for filterqueen vacuum
Put a broomstick or such down the hose, something may be stuck. Look inside with the bag out, is there a screen before the motor?
Dec 01, 2013 | Filter Queen Majestic Canister Vacuum
I cleaned all the filters and it doesn't have any suction
Check the hoses for a clog. Sometimes the hoses themselves will get clogged and cut off suction -- other times it happens between the beater brush and the hose (within the cleaning head itself). If this is the case, when you turn on the vacuum it will make a higher pitch sound than normal, and sound like it is working really hard, even thought there is no suction. If you can't reach the clog, but you have found it in the hose, you can usually use a coat hanger to either loosen it up or remove it completely from the hose. If this does not work, you can try loosening the clog with another vacuum. Just use the second vacuum to reverse the normal air-flow through the hose ... sometimes this will loosen it up and get your equipment to work.
May 26, 2011 | Eureka 3276AVZ Bagless Upright Vacuum
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
No suction
Sucked up a sock?? No seriously.. it may be as simple as that or that an on board filter is clogged. Check your manual for all filters and Hepa/screens and others. Also, is the unit making any odd noises since the non -suction scenario? Whining or screeching sounds, where is the motor impeller/vac bearing or similar is damaged or a hose is kinked within hte unit itself.. <not normally unless the unit has been taken apart and placed back together and crushed the main return vac hose. .
Apr 30, 2010 | Dyson DC14 All floors Bagless Upright...
Extreme vaccum has no suction.
Make sure you put the dirt cone back in the bucket to create the tight seal. You will have no suction without the dirt cone.
Bob
http://evacuumstore.com/
Dec 10, 2009 | Electrolux Centralux Vacuum
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Black & Decker 15.6 Volt DustBuster Vacuum Logo
47 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
