Question about Mighty Dwarf Black Authentic Vibration Speaker 360 Omni Directional Sound
The charging port hole was loose when purchased will not charge.
The light won`t come on when plugged in, will not play music from chip, has not worked from time of purchase.
The product can be replaced by the manufacturer by going to the Mighty Dwarf website. If you purchased an authentic product from an authorized retailer then you are going to be well taken care of.
The best thing to do is open a support ticket on the Mighty Dwarf website and begin the process.
There is no user serviceable parts in the speaker. Opening the speaker will void the manufacturer warranty.
Posted on Jan 17, 2013
  • Mary Lacosse Jan 19, 2013
    Thanks for the info, I will do that.
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
I have the ICF-CS10iP dream machine my ipod (which is a 2nd generation touch) will charge but wont play music what is wrong it use to beable to
This happened to me - the radio also wasn't playing. I was able to resolve it by resetting the unit using the instructions in this manual: https://docs.sony.com/release/ICFCS10IP.pdf
I hope that helps!
Jan 25, 2011 | Sony ICF-C1IP (Black) Docking Station
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
May 21, 2010 | Finis Swi MP3 Player
My 3G ipod works fine when charging in my vehicle (lighter power supply). It does not hold a charge at all though. It also works when charging w/ the wall charger in my home. I can not get it to charge...
Perhaps you are attempting to charge it with it turned on. Most mp3 players have to be turned off to charge the battery. This is because the overvoltage of the charger would damage the delicate cmos chips otherwise. SO when charging through your USB port plug it in and then turn it off using the software switch which is usually "hold down play button" for 4 secs. Don'rt use the mechanical switch (if it has one)
Mar 20, 2010 | Apple Audio Players & Recorders
Portable dvd player will not play off outlet or car charger
There must be something wrong with the amount of power the power supply is providing. I would try and purchase another power supply, and see if it still happens. Another thing it could be is the port where you plug in the power cord, is the port loose or can you move it? If this is the case, it might not be receiving clean power.
Jan 23, 2009 | Protron PDV-288 7" LCD Portable DVD Player
DS Battery Problem
it's your charging port, it's not charging the battery
Jul 16, 2008 | Nintendo DS Console
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
Mighty Dwarf Black Authentic Vibration Speaker 360 Omni Directional Sound Logo
183 people viewed this question
Top Mighty Dwarf Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mighty Dwarf Audio Player and Recorder Expert? Answer questions, earn points and help others
