Question about Konica Minolta Office Equipment & Supplies
I have a error in konica 7055,code F-56 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 1,294 Answers
Enter in the service mode,select SC code history and read the code description.
Posted on Jan 30, 2013
  • 42 Answers
SOURCE: Solution for KONICA 7020
E-56 is a main board problem.
Posted on Jul 07, 2008
firecontrol7
  • 6161 Answers
SOURCE: need ecm code for konica 7055 or a reset code
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Posted on Jul 24, 2009
  • 1294 Answers
SOURCE: F-34-1 in Konica 7055
This code refer to a fusing unit malfunction.High fixing temperature abnormality.The TH1(thermofuse) detects more 220 C.Possible causes the fixing heatre lamps or the thermistors defective.Verify the continuity,and verify the printer control board and the DC supply unit.Be sure to repair a defctive part before setting the 25 DIPSW 3-1 to 0.
Posted on Sep 26, 2009
  • 990 Answers
SOURCE: I have a error code F-34-1 in konica 7055
Hello sir; You need to reset, the procedure as follow; power off the machine, hold down 2 & 5 while you power on machine,then chose 1 soft switch setting, then dip switch 3 bit 1, 2, 3, 4 set to 0. then turn power off and back on.
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Posted on Oct 15, 2009
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
F52-1 error code on konica 7055
Check all fans, and filters might need a good cleaning around them.
May 27, 2014 | Konica Minolta Copier Toner 7055/7065...
Error code E-22-1
Please the copier model.In Dialta model the code refere to main body main motor malfunction.
Feb 12, 2013 | Konica Minolta Copier Toner 7055/7065...
Error 56-03 di 7210
press stop button then on power button then fix this error.
this problem abnormal power.
Jul 13, 2012 | Konica Minolta Office Equipment & Supplies
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Sep 26, 2009 | Konica Minolta DiALTA Di200 Copier
Sep 26, 2009 | Konica Minolta Office Equipment & Supplies
Jul 07, 2008 | Office Equipment & Supplies
47 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
