Question about Maytag Neptune MAH5500B Front Load Washer
Need to drain the tub before moving
We are in the process of moving and I know that my neptune washer has a water reserve of some sort under the tub. I would like to know how to drain it out so I don't hurt myself getting it moved to it's new home.
    Scholar:
  • 87 Answers
It should all be drained out of there except a little in the hose. The sloshing sound you hear in there is not old water or stored up water. It is a liquid in a balancing ring that is sealed shut but it sounds like the water is in the tub. The best way to get all the water out is to take a wet vac and **** out the water from the drain hose. Just put you hand around the 2 hoses to kind of seal it and lay it on the floor. Nothing more is really needed to move it. Just don't be too wild moving it around lol. Front load machines are usually very heavy becuase they have cement or heavy pieces to keep the basket from moving around too much in a high speed spin. Good luck
Posted on Jan 24, 2009
Maytag Neptune washer front loader has been great but my wife pointed out that it doesn't drain all the water out? The thought of that old water under the spinning basket (dont know the tech term) doesnt...
Yes, the Neptune is a great washer, arguably. :-> You just may have a clogged pump. Pull the back panel and the rest is evident. Pull baffles, remove gookus, pull pump, clean, etc. ...just like a plumber. Be sure to pull the rubber baffe directly from the bottom of the outer tub. You may need a wet/dry vac to assist you. It's a bear of a job but I do it all the time.
Rich
Western Appliance Repair
Washer Repair Meridian
Oct 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
What is the vertical pumping capacity for a Maytag Neptune washer
I believe it can be done,but I dont think it is recommended by the manufacturer. if you are in a basement and that is your only option, the only suggestion I would have is to build a platform for the waher and dryer to sit on . It would have to be very sturdy. Maytag recommends that you install a wash tub or something of the sort and install a sump pump to pump the water into the drain.
Dec 17, 2009 | Washing Machines
My maytag will not spin on spin cycle. water empties out OK but just won't spin? Muzza
it may have a build up ol lint. under tub or in the drain out let this would leave water under tub / as it floats. and if it cannot drain comlpetly ( no spin also ck for a kink in drain . or a bad pump . hope this helps ..
Dec 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My neptune washer has water in the tub after it
You'll need to clean the strainer. It is located between the drum and the pump. and is connected to the drum with a rubber hose.
Best regards, --W/D--
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mattag Neptune MMAH3000AWA Washer won't run property
sound s like u need a new lock latch and on the 3000s when they burn out it usually takes the top board as well cheaper to get new washer than fix
Apr 08, 2009 | Maytag Neptune Washer
WTW6400SW2 cabrio washer won't drain, humming?
okay, so move your unit away from the wall, if possible take it outside. you need to disconnect the water, power and take the drain out of the wall. tilt it forward so you can get behind it and under it, just rest it on a wall but not too much, on the bottow you will see a pump with 2 blue wires, and 3, 5/16 bolts, take out the bolts and get a bucket ready if your inside it holds about 2-4 gallons if you have scooped most of the water out before hand. take the 2 spring clamps off the rubber joint and pull out what ever is in your drain pump, use your fingers to work it out.
Mar 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I HAVE A MAYTAG NEPTUNE WASHER, MODEL NO. MAH4000AWW. WASHER WILL NOT SPIN OUT. WATER STAYS IN TUB. I DON'T KNOW WHICH PART NEEDS TO BE REPAIRED, COULD IT HAVE ANYTHING TO DO WITH THE CONTROL BOARD?
It is the drain pump and motor assembly that does not remove the water from the tub. Althought it spins, water is not sucked out of the tub. Try replacing the drain pump and motor assembly. Part no. 22003059.
I did and my washer works well now.
Bill P
Herndon, VA
Mar 30, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
379 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
